Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-30-2017, 04:36   #1 (permalink)
Member: 1191636
Thanks Meter: 6
Talking iPhone 7 plus error 9
hi
i have iPhone 7 plus get error with iTunes
i change ic changing but the same error 9
i change cable data but the same error 9
thanks
The Following User Says Thank You to mustafa12 For This Useful Post:
Old 07-30-2017, 08:05   #2 (permalink)
Member: 1760128
Thanks Meter: 56
error 9 is related to NAND!
The Following User Says Thank You to tomerzhr For This Useful Post:
Old 07-30-2017, 22:08   #3 (permalink)
Member: 1191636
Thanks Meter: 6
thank you
but i restore with 3utools give error -1
Old 07-30-2017, 23:44   #4 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Error -1 is baseband ic
The Following User Says Thank You to HDccam For This Useful Post:
Old 07-31-2017, 21:47   #5 (permalink)
Member: 1191636
Thanks Meter: 6
thank you
error 9 use mac with itunes
error -1 use pc with 3utools
what i do
reball nand at the first
or rebll baseband
Old 08-01-2017, 17:50   #6 (permalink)
Member: 2624117
Thanks Meter: 2
Reball nand first mate
Old 08-02-2017, 02:17   #7 (permalink)
Member: 2729413
Thanks Meter: 15
check the lines from the EEPROM to the CPU (SDA and SCL) and see if they read around .42 in diode mode.
The Following User Says Thank You to johnbaker26 For This Useful Post:
Old 08-03-2017, 03:49   #8 (permalink)
TGB
Member: 2737783
Thanks Meter: 39
I saw this tutorial on 3uTools web, you may have a look: How to Fix Error 9, 4005, 4013 or 4014 in iTunes/3uTools?
The Following 2 Users Say Thank You to TGB For This Useful Post:
Old 12-30-2017, 10:35   #9 (permalink)
Member: 1943302
Thanks Meter: 5
i rebbaling nand but same problem plz help me
Old 12-30-2017, 14:05   #10 (permalink)
biaby's Avatar
Member: 523332
Thanks Meter: 273
juste use ORIGINAL CABLE and your probleme will solve
Old 07-02-2019, 12:11   #11 (permalink)
Member: 622715
Thanks Meter: 82
change nand. rebool cpu.. same problem only error 9.. 3gtools error 1
Old 07-10-2019, 09:17   #12 (permalink)
Member: 2430597
Thanks Meter: 83
Has anyone solved the problem? after my fall .... ?
Old 07-18-2019, 10:13   #13 (permalink)
fasttechjlm's Avatar
Member: 268415
Thanks Meter: 57
check PP3V0_NAND 1st. if short to ground, find short and remove it. most of the time its pp3v0_nand. if thats ok check all other nand power rails like, PP0V9_NAND, pp1v8, if they are also fine which most of the time they do. only then you should go for nand reball procedure.
Old 07-18-2019, 19:43   #14 (permalink)
bobo bokota's Avatar
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 496
IPhone 7 /7+ error 9 change tested !
Envoyé de mon SM-A310F en utilisant Tapatalk
Old 03-10-2020, 12:27   #15 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 785
Remove nand
connect with with IPBOX make backup from nand and erase all nand then write backup again and reboll nand ic and put it to phone and flash it this is the procedure which will work 100%
thnks
br
WBGSM
The Following 2 Users Say Thank You to WBGSM For This Useful Post:
Page generated in 0.21581 seconds with 8 queries
