07-29-2019, 17:17 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 252 | iphone 7 plus shorted m2800 can I make jumper instead of replacing?this ic is easily shorted when heated.. |
12-05-2020, 20:43 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Neo-SANA
Member: 292106 Status: Offline Sonork: 100.1582885 Thanks Meter: 116 | You can make jumper to separate coils that can fit into M2800 space on pcb, it works as same but takes much time, better to replace M2800 with new one but make new leaded balls on new M2800 before mounting on pcb. I have trick for old shorting M2800 that fix it and stop the short most times, trick is Take out shorting M2800, test pins with multimeter to ascertain shorting pins, Introduce high current to the pins either with Short Killer tool or take 18650 battery from laptop battery pack, Almost every time i do this fix, shorting gone from M2800. Goodluck. |
The Following User Says Thank You to thomp4pal For This Useful Post: |
