07-20-2020, 07:17 | #1 (permalink) |
Junior Member Join Date: Mar 2010 Location: Israel
Member: 1249675 Status: Offline Thanks Meter: 1 | upgrade iPad NAND from iPhone board it also happened to me on iPad mini 2, I took nand from iPhone 6 and put on the ipad, and the Gyro sensor is always 90 degrees left. anyone knows why? can it be fixed somehow? i used the JC programmer. why can't we take full dumps on the JC prog like we do in EMMC or UFS. |
02-01-2021, 20:01 | #3 (permalink) | |
Freak Poster Join Date: Oct 2011 Location: Annaba, ALGERIA
Member: 1678953 Status: Offline Thanks Meter: 67 | iphone nand on ipad issue Quote:
First i tried like you said and after restoring, the gyro was working upside down, then i formatted the nand with ipbox studio V12.60 then i wrote the needed infos then restored and activated the iPad air, still the same issue, it's upside down, the formatting does not affect the calibration datas in the nand's CE2. | |
02-04-2021, 11:54 | #4 (permalink) |
Junior Member Join Date: Apr 2019 Location: S
Member: 2904736 Status: Offline Thanks Meter: 6 | You have to erase and format NAND with some NAND programmer. After you write/format nand with iPad info it will be ok. Now it have info from iphone device. As I know, naviplus 3000 can't do format with adapter for ipad, you need to take off nand from the board and use 64bit adapter for it. |
