Iphone 7 stuck on apple logo HI, I HAD AN IPHONE 7 FOR SCREEN REPLACEMENT, after diconnecting battery, i removed old screen and put new screen for testing and it got stuck on apple logo, tried putting back old screen, but its still stuck on apple logo, is anyone here faced similar issue? |
maybe is Audio ic problem https://www.youtube.com/watch?v=Bro_fIP2_mY&t=5s if you can restore finish no error try this solution i tried 2 pcs 7 and 7plus it working |
connect all connectors, home button and front camera flex, unless it will not boot up Sent from my iPhone using Tapatalk |
Restore it with original display works for me |
restore the latest firmware and original part to be use. |
There is a way though so make sure you follow these instructions carefully: 1. Hold the home and power buttons down together 2. The Apple logo should disappear from your screen 3. After a couple of minutes it should reappear – when it does, release the buttons 4. Quickly hold them both down again until your device goes off 5. Plug the USB cable into your computer (not to your device yet) 6. Hold the Home button down and plug the cable to your device 7. When you see the Connect to iTunes screen, release the button 8. iTunes will open and the Device in Recovery message will appear Click on Restore If the method can't fix your problem, you may try this method. Fix Issue Like iPhone Stuck on Apple Logo |
Maybe iOS system has some problems. You can try these methods. 1. Force Restart iPhone Press and hold the Power button and Home button together until you see the Apple logo appear on the screen. 2. Put Your iPhone into Recovery Mode 3. Put Your iPhone into DFU Mode You can try force restart the iPhone first. Press and hold the Power button and Home button together until you see the Apple logo appear on the screen. Put Your iPhone into Recovery Mode. If that does not work, put it into DFU Mode. Still does not work. Use iOS System fix software like TunesKit iOS System Recovery, which can fix iOS system problems without data loss. |
Hey, there, to fix iPhone stuck on Apple Logo, you could try the following ways. 1. Force restart iPhone; 2. Apply Joyoshare UltFix, TunesKit, etc professional iPhone repair tools; (no data loss) 3. Restore iPhone via iTunes. (Data Loss) |
