iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides. |
03-05-2010, 14:41 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | iPhone Hardware problems in one thread SOLUTION: RESTORE TO LATEST FIRMWARE.... and ok iPhone 3G Camera Replacement and Installation Download link (Personal account): http://kewlshare.com/dl/e33385045a22...mBOKI.exe.html http://uploading.com/files/H6PAQZQ1/...mBOKI.exe.html plz vote sundorban |
The Following 99 Users Say Thank You to gopalhot For This Useful Post: |
03-05-2010, 14:51 | #2 (permalink) |
Freak Poster Join Date: Aug 2008 Location: vietnam Age: 54
Member: 830301 Status: Offline Sonork: heocon Thanks Meter: 46 | Sorry, the file you requested is either deleted or not found in our database. link is dead please up another link |
The Following 3 Users Say Thank You to Thinh vu For This Useful Post: |
03-05-2010, 15:13 | #3 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | no sim problem REQUIREMENTS: 1.UNA,,LAKAS NG LOOB 2.CROSS SCREW DRIVER 3.CUTTER 4.COATED THIN WIRE 5.SOLDER 6.SCOTCH TAPE OR ADHESIVE ETC.. 7.CHARGING PIN 3310,, OPTIONAL.. 8.PINAKA IMPORTANTE SA LAHAT FINISH PRODUCT: |
The Following 12 Users Say Thank You to gopalhot For This Useful Post: |
03-05-2010, 16:38 | #6 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | how to change iPhone 3G Battery Introduction Each step has a bullet indicating the tool you'll be using. Don't worry about getting lost or confused; hundreds of people have successfully used the Fixit Guide series to repair their laptops. Tools used in this guide -Metal Spudger -Phillips #00 Screwdriver -Spudger Parts relevant to this guide -iPhone 3G Replacement Battery Step 1 — Battery Remove the two Phillips #00 screws from the dock-connector end of the iPhone. |
The Following 16 Users Say Thank You to gopalhot For This Useful Post: |
03-05-2010, 16:43 | #7 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | Step 2 There is a fragile rubber gasket between the silver front bezel and black display assembly. Keep your tool as close to the silver front bezel as possible to prevent damaging the gasket. We recommend a metal spudger for this task, but an X-acto knife should also work, just be careful not to slip. Insert a metal spudger into the seam between the silver front bezel and the black display assembly on the edge closest to the home button. Gently pry the display assembly up from its bezel. |
The Following 13 Users Say Thank You to gopalhot For This Useful Post: |
03-05-2010, 16:47 | #8 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | Step 3 If necessary, insert the metal spudger in the same manner on the side of the iPhone and continue to pry up gently. Stop using the metal spudger once the display assembly is up enough that you can lift it up with your fingers. Step 4 The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet. Rotate the display assembly up until it is at an angle of approximately 45 degrees. |
03-05-2010, 16:51 | #9 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | Step 5 Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1." |
The Following 19 Users Say Thank You to gopalhot For This Useful Post: |
03-05-2010, 16:58 | #10 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | Step 7 Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable. Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone. |
The Following 10 Users Say Thank You to gopalhot For This Useful Post: |
03-05-2010, 17:01 | #11 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | Step 8 Insert your SIM eject tool or a paper clip into the hole next to the headphone jack. Press down on the tool until the SIM card tray pops out. Grasp the SIM card tray and slide it out of the iPhone. |
The Following 8 Users Say Thank You to gopalhot For This Useful Post: |
How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-27-2015 11:57 |
How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 05-21-2013 19:20 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
