02-18-2012, 12:02 | #886 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1671373 Status: Offline Sonork: waqz Thanks Meter: 4 | Sir i have problem in iphone 3gs and iphone 4g, the ringer is working in normal way, but when we connect a call, during call the ringer, hearing speaker and handsfree don't work. Plz help me to solve this problem permanently..... |
02-18-2012, 13:29 | #887 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1654366 Status: Offline Thanks Meter: 0 | Hi Bro, Long time no see you! So i was looking some help here on the forum but no find the solution. Got a 3GS with 2 problems. 1st issue Home bottom doesn't work. I had try fix it with some post wich is on hardware solution thread. no luck. 2nd When try to power up pluged to dock connector the phone going to recovery mode. If i power up only with baterry the phone going ok. I had change the dock and stay the same. Thanks Best regards |
02-18-2012, 14:06 | #888 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
You see it goes directly to recovery because Menu key is short to gnd. Remove DZ9 first from top you can remove all this in picture. Press thanks if solve i will know if worked. | |
02-18-2012, 19:05 | #889 (permalink) | |
Member: 1654366 Status: Offline Thanks Meter: 0 | Quote: I think the problem it's not there, I had check the Dz's and they not shorting with gnd. The problem is when i power up with charging with dock. The phone going to recovery. When i power without charging the phone power up ok. I don't have home buttom too. It's strage because i can put the phone on DFU mode. Thans | |
02-18-2012, 22:25 | #890 (permalink) | |
if you do not want to remove that varistor then not ask me what to do. | |
02-18-2012, 22:48 | #891 (permalink) |
Junior Member Join Date: Feb 2011 Location: Estonia
Member: 1509123 Status: Offline Thanks Meter: 0 | Hi, I have iphone 2g with one problem: on board microphone is not working (sound working, microphone on handsfree is working). The problem is on the motherboard (same results with with different, working dock cables). What could I check on motherboard? Thanks for the help! |
02-21-2012, 16:51 | #894 (permalink) | |
So you are completly right. The varistors are damage. The logic works like a charm after remove the 4 varistors. Please, i'm so sorry for what you have think when i sayed what i sayed. I thought they must to had continued between them and i can measure from a multimeter. So as you know i always say to you, that's i a be grateful to learn with you. Many thanks and the phone works like a charm. hugs | |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
