how to crack mysms(msg forwarding application)????????????? |
i have 3g 2.2.1 have any unlock solution pl |
just install net framwork |
mic problem Help ... Helpppppp i have iphone 3G 8 gb , i faced mic problem in this after 1 min call its mic stopped working but in handsfree mic worked properlly , i changed its complete kit of mic spk and chcrging jack and reflashed again in 2.2 ver but facing same problem if any body have solution then plssssss post thanx xx in advance |
I have Iphone 3g v2.0.1 working but blocked and have another iphone 3g not working cause water damaged but not blocked, is it possible to swap the imei chip accross, is it a BGA chip and where is it located can i have schematic. Is it as simple as removing reballing and reflowing or would it need to be reflashed or something more?:confused: Br Lloydz1 |
I have 2 Iphone 3g's one is imei blocked and wokring, the other is water damaged and not working is it possible to swap imei chip> what type of chip is it (BGA?) and where is it located? would something else need to be done other than just replace chip cause its from other iphone would it need to be flashed?:confused: Br Lloydz1 (sorry about double post the server said error 403 when posted reply) |
mr Quote:
turn on the phone it will work 100% insha ***** i tried it my self wish u all the best |
how to reinstal programs and games who were installed with WinSCP? if i hold my finger for a while onto the games, iphone didn't show the cross "x" :confused: |
I have a lil problem with 16Gb He works great but once I see black screen,but he is working: charging,ringing but with black screen. There are no visible damages inside. I put another LCD - the same result! May be I should disconnect/connect the battery or something else? What can I do? |
help iphone 3G antenna broken swıch Do jumper with ?broken antenna jumper swıch Can |
hi not sure if you can help i have a 1phone 3g 16g o2 uk phone whihc i jailbreaked earlier using quickpwn and i was able to install downloaded apps onto it using itunes but about 4hrs later i get a message saying no sim ??? what can i do to get round this apart from reinstall from itunes my details are network 02 version 2.2.1 firmware 02.30.03 also the file u listed on the forum a couple of pages back i cant download it says it removed thanks for any help |
help iphone 2g unknown problem my iphone shutsoff after removing the cable and if try to restore it comes at apple logo and for 3sec a circle rotates and it again shuts off . when connected to pc/laptop an apple logo appears and then some mattrix coding and again shuts off pls help i have replaced battery need badly |
