06-29-2016, 18:20 | #5761 (permalink) | |
Junior Member Join Date: Jun 2016
Member: 2592162 Status: Offline Thanks Meter: 0 | Quote:
Firstly, you will need to identify the IC by searching for Nokia Lumia Schematics on this forum. Next, you would need to search Google for the replacement IC and do it yourself if you have micro-soldering skills? If not, I would HIGHLY recommend searching Google again for "Nokia Lumia Ic repair specialist near me" I hope this helps | |
07-03-2016, 22:24 | #5763 (permalink) |
Freak Poster Join Date: Sep 2012 Location: So. Cal.
Member: 1817612 Status: Offline Thanks Meter: 13 | First, with phone out of case, connect DC power supply, while watching current meter on supply, turn on phone by shorting to ground the pin 9 on the J2_AP 9 which you will need to keep shorted for about 3 seconds. Watch the current meter for sudden increase of current then make sure there are several distinct increases and changes. This tells you the logic board is likely functioning in the startup process. A steady current drain would indicate a short. No increase in start current means board is not starting. If all appears normal for starting, look carefully at the inductors (on the screen connector check DC continuity make sure they are under 2.0 ohms. If that's ok, make sure screen connector is properly seated and connector is not damaged. Proceed to BL COIL, and Diode low resistance for BL COIL, standard diode test for BL diode. If no issues found change BL IC. |
07-03-2016, 22:31 | #5764 (permalink) |
Member: 1817612 Status: Offline Thanks Meter: 13 | Try DFU mode then restore. If you get a 4005 error repeat this process a few times which can be required. The fact that the phone is recognized by you'd PC, likely indicates U2 OK. Note, that version of U2 is NOT interchangeable with 5c of 5s. |
07-07-2016, 00:12 | #5765 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 225506 Status: Offline Thanks Meter: 31 | please my problem is no call iphone 6 internet is ok 3g safari can navigate in internet that no call the screen call close immediately after hold button green for call is verry urgent thanks |
07-07-2016, 23:12 | #5767 (permalink) |
Junior Member Join Date: Jul 2016 Location: GT
Member: 2595686 Status: Offline Sonork: tmzmonko Thanks Meter: 0 | iPhone 5s Unknown Error (-1) Hey team, Mi iPhone 5s stood in DFU Mode and can't recover nor update it... when iTunes is trying to install the firmware it suddenly stops and returns 'ERROR -1' try again later. I've tried everything already but still nothing has worked. Any help will be greatly appreciated. |
07-09-2016, 08:24 | #5768 (permalink) |
Freak Poster Join Date: Jul 2009 Location: ksa
Member: 1081268 Status: Offline Thanks Meter: 73 | iphone 6 no any camera and flash pls help me https://*********/CqlmRqEdk04 |
07-09-2016, 10:16 | #5770 (permalink) | |
Member: 1081268 Status: Offline Thanks Meter: 73 | Quote:
07-17-2016, 21:22 | #5773 (permalink) |
Member: 2599555 Status: Offline Thanks Meter: 0 | Hello People, A Friend put two IP 4S into the Oven to fix the Wifi Problem . Now i had two IPhone 4S and they are dead! What can i doo? What can i check at the Agelina-A3 U5 to solve the Problem? |
07-18-2016, 11:08 | #5775 (permalink) |
Junior Member Join Date: Sep 2010 Location: bangladesh Age: 31
Member: 1399758 Status: Offline Thanks Meter: 0 | Hello brother i have big problem today , customer give me Iphone 6s for display change after i change the display i see there no light , phone working without light . please help me any one can tell how to i resolve this please |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
