07-18-2016, 19:21 | #5776 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2410110 Status: Offline Thanks Meter: 1 | Iphone 4s water damage working but no image and no Backlight i've already tried replace screen, but remain with the same problem. anyone can tell me what i need to check/replace? thanks a lot |
07-20-2016, 09:09 | #5779 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2600685 Status: Offline Thanks Meter: 0 | Hello everyone please I really do need your help with an hardware solution and institutions on fixing my iPhone 6s ( international version) no service issues or very weak signal........plsssssssssss Last edited by ademola7; 07-20-2016 at 09:15. |
07-23-2016, 18:28 | #5782 (permalink) |
Insane Poster Join Date: Jul 2016
Member: 2601612 Status: Offline Thanks Meter: 14 | I changed the glass screen of ipad mini. I noticed that LCD has problem. A part of LCD has some strange color. What problem can be like this problem? I wonder that just i didn't notice that LCD has problem before changing screen glass. I cleaned connector of LCD. What problem can be? unless originally LCD had problem |
07-28-2016, 15:30 | #5787 (permalink) |
Member: 2604344 Status: Offline Thanks Meter: 1 | Hi, I have iPhone 6 with no service, I rebbaled Baseband IC now is stuck on logo and when I connect it to PC nothing happen, PC is not recognizing my iPhone 6, I have also second one was also no service problem I rebbaled baseband IC and now its no modem firmware. Please give me a hint what can be the problem? After the problems happened I rebbaled on both 2 times the baseband IC. |
07-29-2016, 01:05 | #5790 (permalink) |
Junior Member Join Date: May 2016
Member: 2570836 Status: Offline Thanks Meter: 0 | Hi, you have to check first there is any long screw? If yes, then you have to repair and make micro jumper under the first ground layer, if no long screw then check backlight filters, diode and as well as backlight coil. |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
