Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-29-2020, 12:22   #6556 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
IPhone 7 plus USB device unrecognized, I tried moving pcb from one iPhone 7 Plus to another but it's still same issue..... Need solution asap, pls help
Sent from my M6 Note using Tapatalk
Old 10-23-2020, 10:22   #6557 (permalink)
Crazy Poster
Member: 2964041
Thanks Meter: 3
Originally Posted by desteufelsbrut View Post
Hy!
On my Iphone 2g, the lower half of the touchscreen is not working. I allready changed the Touchpanel, but it won´t work....
thanks and best regards
Have you tried force restarting your iPhone? And how about assistive touch function? If nothing works, it is advised that you should try a third-party tool such as TunesKit iOS System Repair to fix your iPhone's system glitches that may cause your problem.
Old 11-02-2020, 09:06   #6558 (permalink)
Member: 2925956
Hello guys I have a iPhone x which am unable to activate its does not have network issue except when I use 3u tools and verify the phone its says mainboard serial number not found
Old 11-03-2020, 08:38   #6559 (permalink)
Crazy Poster
Member: 2964041
Thanks Meter: 3
fix jailbreak
Originally Posted by prasad3223 View Post
what abt jailbreak?.............................
Do you mean the iPhone jailbreak? If you want to fix your jailbreaking iPhone, then you are suggested to use professional iOS system recovery tools such as TunesKit iOS System Repair, which can fix 50+ kinds of iOS issues and supports all iOS devices.
Old 03-13-2021, 16:33   #6560 (permalink)
Member: 2363401
hi sir can i request apple unlocker cracked version coz i have iphone 5s from canada but forgot the apple id when they gave me is it ok to request thank you
Old 03-13-2021, 23:00   #6561 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Hi rai04 from lovely Philippines You can login on www.icloud.com and reset your apple id password. By choosing you forgot it. If that doesn't work for you. You can look at YouTube and search for Apple tech 752 iPhone 5s bypass to activate.
Old 03-16-2021, 21:34   #6562 (permalink)
Registered User
Member: 567838
Thanks Meter: 64
hi i have a i phone X
it wont enter DFU or recovery
it has a 4 digit pass even that gets stuck
is there any way of forcing this to restore
Old 03-18-2021, 00:50   #6563 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Sure you can force the board to enter DFU mode.
It is a test point on the backside of the board. It is hidden under the sticker.
Connect ground to TP0714 will force to boot in DFU.
But most likely you have a broken button flex and thats why you can not boot in recovery. Try first and other on off button flex
Old 03-18-2021, 00:56   #6564 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
You have to reball or repair broken pads on the mainboard. sandwich boards have a broken connection. All Network ic's are on the lower board. To activate the phone, the server will request information form the lower board.
Old 03-29-2021, 22:01   #6565 (permalink)
Member: 310418
Thanks Meter: 13
Hello:
iphone xs when calling on phone im getting strange noises when on earphone on recivers call phone when on loud is all fine...
Old 03-30-2021, 21:37   #6566 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Originally Posted by lampik View Post
Hello:
Audio codex IC U4902 is responsible for audio when calling. I did a few xs that had crackling sound or no sound when calling. You can twist and bend the frame to test if the sound change. That will indicate if this ic has a bad connection. Replace or reball this ic. Be careful, It's a bit tricky repair. since it is next to the cpu. Hope you have the skills. Good luck.
Old 04-01-2021, 16:13   #6567 (permalink)
Shwana 100's Avatar
Member: 1867291
Thanks Meter: 67
Hi every one
i need Schematics diagram or backlight ways for this model Ipad 8 (A2270 )
can any one help me ?
Old 04-01-2021, 23:53   #6568 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Originally Posted by Shwana 100 View Post
Hi every one
You don't need a schematic. Every ipad is the same. 2 backlight filters at the display connector. 2 diodes under the shield, 2 coils and a driver ic.
Most of the time the filters or diodes burn.. Always disconnect the battery before connecting the screen.
Old 04-02-2021, 23:15   #6569 (permalink)
Member: 310418
Thanks Meter: 13
re:
can You show where is it on the board ?
Can i rehot it ?
Old 04-03-2021, 21:02   #6570 (permalink)
Member: 2474430
Thanks Meter: 3
Cant tell you exactly where it is, but as HDccam said, most of the time it's a burnt diode or filter. They need to be replaced, "rehot" will do nothing.
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.26420 seconds with 10 queries
