06-21-2010, 18:27 | #646 (permalink) | |
Junior Member Join Date: May 2010
Member: 1306445 Status: Offline Thanks Meter: 3 | Quote:
Do I need to solder the 4 points on a specific way (horizontally or vertically)? Thanks. | |
06-21-2010, 21:29 | #647 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1103904 Status: Offline Thanks Meter: 0 | hello iphone 3g wont charge and wont connect through usb hello, iphone wont charge and wont connect to computer i tryed 2 bottom conector of iphone stil not work, the first problem was no signal then from opening and trying to fix ive come across this problem can you please help me? |
06-21-2010, 23:51 | #648 (permalink) | |
Freak Poster Join Date: Jan 2006
Member: 221978 Status: Offline Thanks Meter: 11 | Quote:
Hope it works: Regards | |
The Following 3 Users Say Thank You to schumythebest2 For This Useful Post: |
06-24-2010, 11:01 | #653 (permalink) |
Junior Member Join Date: Oct 2007
Member: 601400 Status: Offline Thanks Meter: 3 | Iphone 3GS in 3g mode no Service hi to all i have Iphone 3GS witch time enable 3g after showing No Service then disable 3g showing service but service coming going pls help me Take advance Thanks |
06-28-2010, 18:27 | #655 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Great Pakistan
Member: 101548 Status: Offline Sonork: 100.1611535 Thanks Meter: 210 | i have iphone 3g all work ok but only display broblem and display light also not working. anyone give me good solution. BEST REGARDS. TAIMOOR KHAN. |
06-29-2010, 10:00 | #656 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 438 | i Have an iPhone 2g when conencted to PC it start CHARGING but itunes DOES not recognize it/detect the iPhone even in recovery... I have cahnge the charging socket / heat the connectors but same !! ANy other Suggestion !! |
06-29-2010, 10:02 | #657 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 438 | i have error 9 on an iPhone 3g when trying to restore thread is : http://forum.gsmhosting.com/vbb/f631...ml#post6020943 with CLIP !! |
06-29-2010, 18:04 | #658 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Perm
Member: 383424 Status: Offline Thanks Meter: 24 | i have stuck problem... iPhone 3G not charging - i make it with changing glass filters, but i can't make iPhone 2G - visualy i see charging and not charging battery with lighting... but iphone not charge - have any solution for it ? or only change micro near CPU - http://img218.imageshack.us/img218/8...gsolutiql5.jpg ? just i no have this micro... |
06-30-2010, 04:34 | #659 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 438 | Quote:
AND is already 24 Hrs NO reply at ALLL !!!! | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
