Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #6635 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Dec 2013 Location: saudi arabiya Age: 30
Member: 2085357 Status: Offline Sonork: 100.1587837 Thanks Meter: 17 ![]() | First check the Ground value in diode mood Then any short or no? If shorted remove the short with short killers Also you use borneo schematic diagrams hardware solutions Don’t forget thanks buttons Sent from my iPhone using Tapatalk |
![]() | #6637 (permalink) |
Junior Member ![]() ![]() Join Date: Oct 2012
Member: 1828794 Status: Offline Thanks Meter: 3 | Hello guys, I have an iPhone X that I fixed a charging ic issue, everything was working well when I tested with jig, but after recalling the sandwich board and soldering it, the phone refused to turn on and now it only stock on 0.025ma current when I power it with power supply. could it be a data issue or a disconnected line. I need your solutions please |
![]() | #6638 (permalink) | |
Junior Member ![]() ![]() Join Date: Oct 2015
Member: 2474430 Status: Offline Thanks Meter: 3 | Quote:
If it worked in a jig but not after reballing the sandwich either you just didn't reball the sandwich correctly (happens all the time) or you have a loose pad, which also happens pretty often in the X. Split it again, press on every pad just to make sure nothing is loose and try again in the jig. | |
![]() | #6639 (permalink) |
Junior Member Join Date: Jan 2023 Location: USA Age: 28
Member: 3029429 Status: Offline Thanks Meter: 0 | Good post! What's the right length for your book? The answer is simple. There is no "right" length. You must research the marketplace. There are clear trends within it that will help you decide what works for your book. |
![]() | #6641 (permalink) |
Junior Member ![]() Join Date: Oct 2009
Member: 1139080 Status: Offline Sonork: juniorr Thanks Meter: 1 | does anyone know what files are used for plist iCloud unlock lost mode or clean seems like a lot of people have this service but I want to find the source or see if I can do it my self for my repair hobby seems like a lot of scams not he site can anyone confirm this is a legit method and who is the actual source |
![]() | #6642 (permalink) |
Junior Member Join Date: Jun 2013 Location: HONGKONG
Member: 1967391 Status: Offline Thanks Meter: 0 | Can we show battery percentage in iPhone 12&above as we wish ? If yes can u explain the solution? I am a seller who want to increase a little than which I have in few phones. Otherwise cant sell. Thanks in advance |
![]() | #6643 (permalink) | |
Just suck it up and do it right and put in a new one. | |
![]() | #6644 (permalink) |
Junior Member Join Date: Feb 2023 Location: Germany
Member: 3032233 Status: Offline Thanks Meter: 0 | Hello, I am new here in the GSM forum and have a problem where I can't get any further. I have received an iPhone 12 Pro which has not been opened before. The screen brightness is permanently set to about 20%. A hard reset or a reset to factory settings did not bring any success. Even turning off the automatic brightness control did not change anything. It is strange that TrueTone does not appear in the settings. However, the display is original and does not appear in the service history. So I opened the unit, after heating it with the separator, the display lit up normally again and the brightness could be adjusted. TrueTone also appeared in the settings. After a restart, however, the display was dark again as before. Afterwards, I copied and flashed the EPROM data again with the JC V1S programmer to test it, but the display remained dark. Now I don't know what to do. Unfortunately I don't have a replacement display, could it really be the display? Or what could it be? |
![]() | #6645 (permalink) | |
I had one I couldn't get out of that mode until I ran across a post somewhere that if you change the display zoom it snaps out of it. (settings->display & brightness ->display zoom) Was stunned when it worked! So worth a try. Given all you've done, your issue may be something more. Maybe try a new ear speaker flex.. | |
The Following User Says Thank You to eldavies For This Useful Post: |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
