Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-17-2023, 13:16   #6646 (permalink)
Member: 3032233
Originally Posted by eldavies View Post
I don't necessarily have exact answers for you but it's a common issue in the 12 that if it doesn't see the ear speaker flex that the screen is stuck on dim. It's essentially a software bug.
I had one I couldn't get out of that mode until I ran across a post somewhere that if you change the display zoom it snaps out of it. (settings->display & brightness ->display zoom) Was stunned when it worked! So worth a try.
Given all you've done, your issue may be something more. Maybe try a new ear speaker flex..
Hey Eldavies,
Thank you for your quick reply. I tried it out straight away and, lo and behold, the display can be adjusted normally again. After a restart, however, it is dark again. Did you manage to make the state permanent?
Old 02-17-2023, 21:22   #6647 (permalink)
Member: 2474430
Thanks Meter: 3
Originally Posted by apple_hobbyist View Post
Hey Eldavies,
As I said, try a new ear flex. Also of course make sure the connector is clean & not damaged. You'd lose Face ID unless you move over the flood illuminator but at least you'd know you have a handle on the cause.
I'll bet if you test the ambient light sensor right now it's not working...
New tools exist for creating a flex that's properly programmed, if you don't do soldering.
Old 03-06-2023, 09:40   #6648 (permalink)
Member: 3032134
Ear speaker not working on call in iphone 12
Ear speaker not working on call in iphone 12.
loud speaker is working fine..
Old 03-13-2023, 20:11   #6649 (permalink)
Member: 72939
Thanks Meter: 30
clean earpiece with alcohol and toothbrush , **** across with canned air
Old 05-04-2023, 10:48   #6650 (permalink)
Member: 310418
Thanks Meter: 12
battery iphone xr change/problem
hello, i have a problem with battery for iphone xr,
can i use JCID to change serial number of battery and iphone will not shown unktown hardware ?
Old 05-04-2023, 17:07   #6651 (permalink)
Member: 2987051
Hi all, I downloaded some kind of call tracking app and my phone started getting really hot. I uninstalled the apps, but the problem remained. What could be the problem?
Old 05-10-2023, 21:04   #6652 (permalink)
Member: 1285970
Thanks Meter: 4
do you have tools for bypass iphone 6
Old 05-31-2023, 09:00   #6653 (permalink)
Member: 3039483
Hi, I got an iPhone Xs which is badly damaged but it seems to be working in general.
But the battery has been accidentally connected to the button flex cable connector once, and it unfortunatly fits the connector. Now the buttons aren't working and the device reboots every few minutes. Even in powered off condition, a laboratory PSU shows astable/switchting consumption between 0 and 10 mA, or between 10 and 12 mA. I think it's floating. Maybe R4310 or C4310 are damaged? Or the input of the IC?
Booting up is still possible using a Lightning cable.
I have to look under the microscope but R4310 seem to be missing at all (or it's extremely small). Is it a pullup/pulldown resistor? Should have 100 ohms as far as I can tell from manual.
I just try to do data recovery but it is nearly impossible with the frequent reboots. So I'd be fine with the button/trigger being completely out of order; the device won't get repaired. That means, just removing components would be OK, as well as adding temporary bypasses. But I don't know where to start.
Thx in adv
Old 06-01-2023, 00:49   #6654 (permalink)
Member: 2474430
Thanks Meter: 3
Thx in adv
If the phone doesn't see the home button flex it will reboot at exactly three minutes. Watchdog timer. So step one is to buy a completely new flex and just plug it in. No need to fully install. Same is true with the USB charge flex, might be worth plugging in a known good OEM APPLE flex. Or pop the board into another housing if you have one.
R4310 is critical to actually press the button however it shouldn't be the cause of the reboot, if missing it would simply act like the power button isn't pressable.
Ive found the only somewhat workable tactic for data recovery if it's insistent on rebooting every three minutes is through icloud sync. Make sure icloud size is big enough, it has access to wifi, and just let it loop. Maybe others have better tactics...
It's gonna have 2-3 minutes each reboot - not enough to upload the large video files but decent chance of getting most of the other stuff - eventually.
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.14727 seconds with 10 queries
