09-08-2010, 15:51 | #736 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 331337 Status: Offline Thanks Meter: 72 | |
09-11-2010, 19:33 | #737 (permalink) |
Insane Poster Join Date: Feb 2006 Location: romania!...anywhere
Member: 235665 Status: Offline Thanks Meter: 10 | iphone 4 speaker i to all!!i have a problem with an iphone 4...a speaker problem.when is playing music or someone calls.the sound becames very metalic ,pitched... sometimes is working fine,sometimes not.i opened the phone.there is no water damages. the phone seems to be brand new. i have no clue about it....i would try to change charging flex and audio flex(with side buttons)... when i press the socket of charging flex ...the sound seems to be ok... i wonder if is an audio ic or something like that? please,any ideea? |
09-12-2010, 00:59 | #739 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1391977 Status: Offline Thanks Meter: 0 | 3gs unlock not working w/ ultrasn0w Aloha, I have an iphone 3gs that was once unlocked by blackra1n. One day it wasn't unlocked and app was no longer on the springboard so i was unable to reload blackra1n. It is currently jailbroken and I have cydia, but ultrasn0w will not unlock this phone. Its on versuib 4.0.1 (8a306) model MB715LL firmware 05.13.04 Ultrasn0w loads but when sim is installed it will say searching.... for about 3 to 5 mins, then No Service. I have installed and removed so many times but still nothing. I have tried airplane mode off and back on but nothing, Please help! Mahalo |
09-15-2010, 20:25 | #740 (permalink) |
Insane Poster Join Date: Apr 2008
Member: 761694 Status: Offline Thanks Meter: 2 | not connecting in itunes i have iphone 3g shwoing apple log on screen going recovery mode and dfu mode but not connecting with itune in pc.i had change chargingjack flex but still same its hardware isshu.ihad check cable and pc installation othe iphone it connecting ok.help me out. |
09-15-2010, 20:30 | #741 (permalink) |
Member: 761694 Status: Offline Thanks Meter: 2 | i have iphone 3g shwoing apple log on screen going recovery mode and dfu mode charging ok but not connecting with itune in pc.i had change chargingjack flex but still same its hardware isshu.ihad check cable and pc installation othe iphone it connecting ok.help me out. iaahu its charging first ;ow battery symbol then its charge with cable and hang on apple log but not connecting in itunes in any mode help me hardware. with pic thnks |
09-16-2010, 15:33 | #742 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 635560 Status: Offline Thanks Meter: 3 | touchpad killer Hi I have a iphone 3gs who killed all the touchpad I want to put in. when I go to menu all touch is working but left line is not working. I have test a new touchpad in another Iphone it work perfectly, I put it in this iphone : the left line not work and when I want to test it in the another iphone the touchpad not working . Excuse me for the bad english and thanks for your help |
09-18-2010, 10:59 | #744 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 656489 Status: Offline Thanks Meter: 4 | Good morning. They have brought me an iPhone 3G which has the following problem. Having trouble microphone. You can record with the recorder without problems, but in a conversation does not do its function microphone and speaker noise is heard. What could be? Thanks |
09-18-2010, 11:39 | #745 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 936896 Status: Offline Thanks Meter: 14 | I have a problem with my iphone 3g 8gb. Is't stuck on recovery mode and after trying several methods(including some suggested in this website) still the phone is stuck in recovery mode. I tried ireb,recboot and other stuff. I think is a hardware problem so I wanted to know if someone knows what is related to and how can i be fixed. regards |
09-19-2010, 07:07 | #746 (permalink) |
Junior Member Join Date: Aug 2007
Member: 558946 Status: Offline Thanks Meter: 2 | I have a small problem. Whenever my iPhone 3G goes to sleep, it will just shut off. Wont come back on. I have to hold home and power for 10 secs to revive it. This problem will not happen if connected to charger/USB. This had been dropped from height and thus this happened. Any solutions? |
09-19-2010, 11:53 | #747 (permalink) |
Junior Member Join Date: May 2007 Location: Kyiv
Member: 512716 Status: Offline Thanks Meter: 0 | Greetings, masters. Have an Iphone 3g with no sound in right earphone (when earphones plugged in). Earphones is 1000% working. Changed earphone flex and result is the same. What should I change next? Thanks in advance. |
09-19-2010, 15:09 | #748 (permalink) |
Member: 1397918 Status: Offline Thanks Meter: 0 | Re: MPhoneClinic Hi, Can you please indicate the part number or name of the component to renew? I've had this problem for quite a few months now and the symptoms on the page are exactly as per my symptoms. Greatly appreciate your help. Cheers |
09-20-2010, 10:17 | #749 (permalink) |
Member: 1398506 Status: Offline Thanks Meter: 0 | Iphone 2g speaker...again Ok...here is my story. I have a 2g Iphone 16Gb. I had it for at least 3 years. After I received it, jailbroken it, activated it(there were no iphone sellers in my country at that time) in a day or 2 suddenly there was no sound comming out of the speaker. Actually there was a very faint sound if I put the speaker phone directly to my ear, but this was very very low. I have to say that once in a while the sound was back on to it's full potential, but then it disappeared again. I searched then all the solutions at that time(there were very few) but still no luck. Out of luck I solved the problem by connecting the iphone to charge in a car that had an USB connection....an Voila...for about 3 years I had a fully functional phone. Now the problem is back. I said to myself...this has to be repaired once and for all, so I toked it to a Phone service department. I explained the whole deal, and they said the problem must be the phone speaker(even though I know sometimes the sound is back on so the speaker can't be broken. I even measured the resistance of the speaker...so the coil was ok), but I said...this are professionals...so they changed my speaker. Indeed the phone worked for ~1 month...but now the problem is back. I'm determined to buy from ebay a new speaker, a dock ribbon cable, and if that can't solve it...I'm beaten. So....any idea is welcome. I have to say that the phone was firmware updated numerous times...so I don't think this is a software problem. Also the ear speaker is fully functional, I can speak over the phone OK, only the buzzer(speaker) is problematic. Thanks, I hope someone here gives me an Idea. My next step is to retry the car experience, after that the spare parts.... |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
