03-26-2024, 01:25 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: world,mobile sevices
Member: 1867291 Status: Offline Thanks Meter: 67 | an iphone XR not charging when device working , but the device charging when it turn I have an iPhone XR that doesn't charge completely. I changed the problem to IC Hydra, but now it charges. If the handset works, it doesn't charge at all I hope anyone has information about the problem to advise us, I would be very grateful. With respect to everyone. |
The Following User Says Thank You to Shwana 100 For This Useful Post: |
03-26-2024, 01:34 | #2 (permalink) | |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 496 | Quote:
What was the diagnosis did you make on charger Wireless ? and USB cable? Before changing here, you had to check the two parts Wireless ? and USB cable Wireless = Tigris USB cāble = Hydra | |
03-26-2024, 02:07 | #3 (permalink) |
Member: 1867291 Status: Offline Thanks Meter: 67 | Hello brother, I checked the cable charger and wireless charger before replacing both ICs, none of them charged, so I replaced the Ic hydra and then charged, but the charger does not charge until the device is turned off, thank you for your answer. |
04-04-2024, 00:00 | #4 (permalink) | |
If I understand correctly, before replacing the Hydra the phone is not changed either on Wireless ? or USB. What was the output on Vbatt and VUSB? From what I understand from this scenario, tried to change Tigris | |
04-07-2024, 19:49 | #5 (permalink) |
Member: 1867291 Status: Offline Thanks Meter: 67 | Hi Bro I found the problem ,this line has a short circuit between Hydra and CPU (HYDRA_TO_NUB_INT). https://i.imgur.com/IOZgaRh.png |
