12-13-2012, 10:58 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: tbilisi, georgia Age: 33
Member: 1679251 Status: Offline Thanks Meter: 385 | IPHONE...IPAD... tested solutions for beginner technicians i hope this useful, i'll help some people and they'll help me too in the future Last edited by acyl2000; 08-10-2013 at 05:14. |
12-13-2012, 11:05 | #2 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - it often happens that, when you change the screen on iPad 3 and then switch on it has half dark screen or totally dark. SOLUTION - on the back side of the motherboard, near the battery connector there are backlight filters. they just need shorting. you can see that with microscope too. http://forum.gsmhosting.com/vbb/f631...o-lcd-1568207/ |
12-13-2012, 11:28 | #3 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - iphone 4 no ringer no sound in buzzer SOLUTION - ringer ic needs to remove and the pins n the motherboard side shorting |
The Following 6 Users Say Thank You to Levani_Pmic For This Useful Post: |
12-13-2012, 12:15 | #4 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - after repairing iPhone, searching without sim or no service. this is ios 6 problem. SOLUTION - connect itunes and correct date and time, and restart the phone. |
The Following User Says Thank You to Levani_Pmic For This Useful Post: |
12-13-2012, 12:23 | #5 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - 3gs. water damaged home button not work or itself work SOlUTION - the part which is marked on the picture might be corroded and needs cleaning |
The Following 4 Users Say Thank You to Levani_Pmic For This Useful Post: |
12-13-2012, 13:05 | #6 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - iPhone 4S after water damaged battery pin 1 and pin 4 is short, and phone not turn on without charger SOLUTION - check this capacitors, any corroded or damaged, remove it |
12-13-2012, 17:47 | #7 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - iphone 4S after repair no light on LCD and PMIC getting hot SOLUTION - change this component, you might see that in the microscope |
12-15-2012, 16:18 | #9 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - ipad 2 not charging or charging only when switched off. SOLUTION - if flex charger works, check there might be burnt |
12-17-2012, 10:59 | #11 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - iPhone 4 after water damaged battery pin 1 and pin 4 is short, and phone not turn on without charger SOLUTION - check this capacitors, any corroded or damaged |
12-19-2012, 18:59 | #14 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - iphone 3g switches off when it's on a sleep mode SOLUTION - change power key flex and(or) camera http://forum.gsmhosting.com/vbb/f631...o-off-1580909/ |
The Following 2 Users Say Thank You to Levani_Pmic For This Useful Post: |
12-21-2012, 08:24 | #15 (permalink) |
Member: 1679251 Status: Offline Thanks Meter: 385 | PROBLEM - ipad 2 has no brightness SOLUTION - change this component |
