Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-18-2016, 22:06   #1 (permalink)
Member: 1222631
Thanks Meter: 24
iPhone NAND Programmer ?
Hey did anybody get the 64bit NAND programmer for iPhone? I would like to get that to make memory upgrade. Or should I wait for the prices of these machines to come down?
Old 04-22-2016, 22:43   #2 (permalink)
Member: 2136861
for 32 bit 770$
for 64 bit 820$
Old 04-23-2016, 12:59   #3 (permalink)
Member: 16700
Thanks Meter: 11
Is this possible?make 5s with 16 to be 64?
Old 04-24-2016, 02:40   #4 (permalink)
tochits's Avatar
Member: 856640
Sonork: 100.1606320
Thanks Meter: 282
yes possible.by replacing 64gig of RAM(NAND IC)
Old 04-24-2016, 12:53   #5 (permalink)
Member: 1939450
Thanks Meter: 162
Iphone 32bit flasher can be made easily for under 100 dollars.
Get an iphone 4 model 3.2, debugging cable and a nand flash socket. And get the programmer software. PM for link.
iphone 64bit, i think (working on it) also be made by yourself. Get and iphone 6 motherboard and a nand socket and engineering cable (can not be made by yourself) and also the software. pm for link.
The Following User Says Thank You to timvandenboo For This Useful Post:
Old 05-02-2016, 06:11   #6 (permalink)
Member: 1939450
Thanks Meter: 162
Check this post for link: http://forum.gsmhosting.com/vbb/f631...-wifi-2075558/
Old 10-06-2016, 22:24   #7 (permalink)
Member: 568
Sonork: 100.1646534
Thanks Meter: 5
Question
Do you have this "engineering cable (can not be made by yourself) " what is inside?
And where to get "programmer software" ?
Thanx!
Old 10-07-2016, 11:31   #8 (permalink)
Member: 1939450
Thanks Meter: 162
Thanx!
I suggest you to by the IP box. No problems anymore and quick 32 /64 bit programmer. It will safe you a lot of time (i just gave up on finding it out by myself)
Old 10-14-2016, 20:40   #9 (permalink)
Member: 568
Sonork: 100.1646534
Thanks Meter: 5
thanx for replay, I know about IPBox v2, nice device on Cortex M4
Old 10-14-2016, 21:47   #10 (permalink)
Member: 1222631
Thanks Meter: 24
I got IPBox v2 and works great.
Old 05-21-2017, 04:15   #11 (permalink)
Crazy Poster
Member: 2601523
Thanks Meter: 19
NAVIPLUS PRO3000 is more good!
Old 05-22-2017, 00:27   #12 (permalink)
Member: 1668980
Thanks Meter: 34
Naviplus pro3000 will not work for my pcie nand from iphone 6s to ipad pro
different socket
anyone solution to reverse engineer the naviplus pro3000?
Old 08-06-2017, 21:29   #13 (permalink)
Member: 1530609
Thanks Meter: 4
I got confused guys what can I actually program with DIY flasher made from iphone 4. Will I be able to flash nands from ip5,5c,5s,6 ? And for ip6s and above i will need another flasher? What phones / ipads ip4 would allow me to re-program? Someone said that for newer nads i would need ip6 board and special cable but no one anywhere gave any details how to make a flasher out of ip6 borad. Anyone knows? Thanks
Old 08-07-2017, 06:24   #14 (permalink)
Member: 2691507
Thanks Meter: 100
If you don't know how to use google search, much less you'll be able to make this device your self.
Here someone already gave you the info, but I don't think anybody will give you a written down step by step.
IP box 2 is less expensive, but like I said, you get the box and then you need to learn how to use it, and unsolder, and solder, and but hot air station, and tools, not as easy as it sounds.
I'm not in this forum looking for customer to sale them a programmer, so I'm telling you exactly what it is.
Old 08-07-2017, 08:45   #15 (permalink)
Member: 1530609
Thanks Meter: 4
That's not very kind mate to tell me I don't know how to use google but thanks for the reply... Belive me or not but I did google research to save myself a pain in the *** waiting for someone to kindly reply on the forum and get the answer straight away but my searches did not give what I wanted. Let's leave the manual part of the repair here as this is not the case in my question (I've managed to sucessfully remove,clean and re-ball nand memory ic, and got all the necessary equipment). The reason why I don't know what can I program with IP4 board 3.1 ver is that ip4 nand layout is very different than anything else. And simply nands from 5, 5c,5s,6 wouldn't be a direct fit. Regarding ip6 board being used as a programmer there isn't any info: does is have to be a specific revision of a board, how can u use it as a programmer if all the booloader holes have been patched from ip 4s on ? And that's why I've asked here but looks like it's not gonna take me to anywhere...
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.19629 seconds with 7 queries
