11-08-2015, 20:31 | #1 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1672230 Status: Offline Thanks Meter: 0 | Front Camera not working Repair went well. after testing front camera will not work and also the headset ear speaker not working. anything to check beofre buying new ribbon camera unit? |
11-08-2015, 23:54 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | Check if your rear camera still works and torch light. If they dont work, you need to jumper ic u2301 and no need to replace the camera. If all works fine, accept the front cam. Replace the front flex. |
The Following User Says Thank You to HDccam For This Useful Post: |
11-11-2015, 00:51 | #5 (permalink) |
Member: 1732818 Status: Offline Thanks Meter: 532 | It could be, you have damaged the board. You used a long screw at the LCD connector. Now the tracks under the screw hole are cut or shorted. |
11-13-2015, 01:24 | #7 (permalink) |
Member: 1732818 Status: Offline Thanks Meter: 532 | Take the screw mount of the board. You can remove it with your soldering iron. Its low melting solder. You have to gently scrape away the black top layer. And under there you find very small board tracks. You have to connect every broken connection. Its the same as repairing an iphone 5s with blue screen and error 9 and 14. Fixing the damaged tracks. http://forum.gsmhosting.com/vbb/f631...nside-1850234/ |
