iPhone X PP GPU short ok. I have seen this twice now. That last one was a bad A11 I have a iphone X with a PP GPU short All the caps on that rail are low ohms. Is this a signature fail? Last time I started pulling caps one at a time until there were none left. Then pulled PMIC then the A11. The short went away with the A11. |
Anyone? Is there a highly active forum for micro solder technicians.. ? I find some info here but it is sparse. |
Using thermal imaging "I figured out a more precise method for my Flir" using a iPad as the display and using a lens distance of less than 3". I am 100 % positive this is a A11 chip as well. How the hell do you fix this? To see a video of the FLIR as the board powers on visit my youtube channel. kcmicrotronix The name of the video is "iPhone X PP GPU short" |
I am officially pulling the plug on the repair and calling it a defective A11. no reparable. |
check this video, i hope it helps . https://www.youtube.com/watch?v=RBA7sYub8mI |
Hello, PP_GPU is a very low value in resistance/diode mode, are you sure you're facing a short on that line? I have an iphone X that is booting normaly, the value for this line is 4.5 ohm. |
