Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-08-2020, 17:07   #16 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
We use Jc pro for programming WiFi and by BT address was written successfully,but on 3u tool error is 4010 and on iTunes error is 9.
It was icloud having toshiba nand HDd and I use scan disk 128 gb.
Sent from my iPhone using Tapatalk
Old 01-08-2020, 17:10   #17 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
3utool iTunes flashing have some different code.
Old 01-08-2020, 22:15   #18 (permalink)
Member: 1964660
Sonork: No
Thanks Meter: 54
Nandini pro is very useful tool!! Many nand is not supported!!!!
Old 01-09-2020, 05:43   #19 (permalink)
Member: 775445
have any problem while using scandisk 128gb insteadted of toshiba 16 gb on ipad air a1475 convert to ipad air wifi only?????
Old 01-09-2020, 11:05   #20 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
Originally Posted by APPLE-LINKS View Post
is it possiable to upgrade ipad air 16gb to 128gb by using jc pro????
Yes is compatible but only wifi , if errors with itunes or 3u format nand and try again
Old 01-12-2020, 03:30   #21 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
I just try with iPad own nand chip it’s 16GB it flash successfuly,but with 64 and 128GB chip 3u tool stucks on 20% “unmounting file system”.no further flashing go on.
Old 03-06-2020, 14:17   #22 (permalink)
Member: 1855668
Have someone tried with writing to Air 2 WiFi H2JTDG8UD1BMR 16GB nand with naviplus 3000s? I'm trying to write to it, and it seems to changing the data, after reading they're present on the nand, but after turning on the ipad, there are old data (unchanged). Naviplus marking the operation as successful. I'm operating on Air1/Air2 adapter.
Thanks for feedback.
Old 08-04-2022, 21:47   #23 (permalink)
sgy
Member: 1364470
Thanks Meter: 2
you cant replace any nand to any device. there is a nand firmware in every ios update. so if there is no new supported nand firmware update for the model, you cant put nand from air2 to air1, if there is no firmware in the air1 ios update. Its same on every nand memory on every device. Apple can control nand memory upgrades with it.
Page generated in 0.15033 seconds with 10 queries
