Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 868 | List NON supported nands IPAD AIR / AIR 2 for S/N replace 32G THGBX2G8D4JLA01 32G THGBX2G8B4JLA01 32G THGBX3G8D4KLA0C 32G H2JTEG8VD1CMS 64G THGBX4G9T4KLF0C 64G H2JTFG8PD1MMR Option Nand format :YES NAVIPLUS PRO3000S ADAPTER : 32G THGBX2G8D4JLA01 32G THGBX2G8B4JLA01 32G THGBX3G8D4KLA0C 32G H2JTEG8VD1CMS 64G THGBX4G9T4KLF0C 64G H2JTFG8PD1MMR Option Nand format (with adapter ) :NO EASY56 ADAPTER: Option Nand format : NO SDMILBCF4 THGBX4G9T4KLF0C H2JTFG8PD1MMR TOSHIBA THGBX4T0T8KLF0E 128gb ( tested and non supported ) maybe others... Nand pro with adapter seems to be the only tool to support nand toshiba 32/64 gb Last edited by orx; 06-10-2019 at 09:07. |
The Following 10 Users Say Thank You to orx For This Useful Post: |
![]() | #2 (permalink) |
Junior Member ![]() Join Date: Apr 2019 Location: S
Member: 2904736 Status: Offline Thanks Meter: 6 | Hi everyone, nand with code: H2JTEG8VD1CRM (NAVI read as H2JTEG8VD1CMS) can be read/write with NAVI PLUS with adapter. |
The Following User Says Thank You to ackopk For This Useful Post: |
![]() | #4 (permalink) |
Major Poster ![]() ![]() Join Date: Dec 2012
Member: 1848477 Status: Offline Thanks Meter: 3 | Hello, i have a question here, i stumbled across this post while having issues reprogramming a nand on iPad Air. It's a toshiba 32gb model, the original one that was on the iPad, however changing the serial with NaviPlus Pro3000 doesn't work, always activation error. 3u tools reports the serial as the one i've programmed as well as the Wifi/BT macs. What do you mean by 'not supported' ? As the flash chip is the original one on this iPad, it should work, no ? It means the programmers are buggy and not doing the job correctly ? I've also tried with nand pro and result was the same, activation error. Serial was bought from gsmfather for A7/A8 specifically. Any input would be great, thanks ! |
![]() | #5 (permalink) | |
Member: 1825965 Status: Offline Thanks Meter: 868 | Quote:
nand model please anyway try with nand pro , format , rewrite boot and write new data | |
![]() | #7 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 868 | non supported from jc and naviplus , as i've write try with nand pro , check list supported nand (about nand pro) nand pro.JPG |
![]() | #10 (permalink) |
Member: 1848477 Status: Offline Thanks Meter: 3 | Yes i can confirm the same, but it's weird, after the write on the nand the ipad is being detected in 3u with the new serial, however itunes will not activate it... Very weird |
![]() | #12 (permalink) |
Member: 2904736 Status: Offline Thanks Meter: 6 | Hello, After i write that nand H2JTEG8VD1CMS can be read/write with naviplus 3000s I was got another ipad with this nand and I unable to edit serial, all time I was got old number on 3uTools. Very wierd situation. Today I have air 2 with THGBX4G8D4LLDYC and also can’t change serial. Again the same situation. naviplus read and write new serial but ipad and 3uTools read old serial and another information. |
![]() | #13 (permalink) |
Member: 1848477 Status: Offline Thanks Meter: 3 | Yes i have seen this also. So naviplus is messing something up it's confirmed. Now i did a test. iPad Air, 3g. Removed resistor, removed nand, changed serial/bt/wf with nand pro, but didn't write boot files just the serial and macs. First time got stuck on waiting for ipad, but will check after a nand reflow now. Do i NEED to write boot files, or format and write boot files ? Also, need to change model from A1475 to A1474 in nand pro, or removing resistor will do it automatically when restoring ? Many questions. |
![]() | #14 (permalink) |
Member: 2904736 Status: Offline Thanks Meter: 6 | Hi, you didn’t need to write boot files, just change model number. After you remove resistor itunes will automaticaly recognize as a wifi model but you must download wifi ios from ipsw site. After you connect with itunes or 3uTools do Shift + restore and chose file that you download from ipsw site. Also check your stencil for nand. Maybe is stencil bad, maybe is wrong diameter hole and ball are not the same. I was have that problem, side hole are the same diameter but nand pads on side are bigger than inside pads so when I put and melt solder past I get different ball size. |
