Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-26-2020, 07:14   #1 (permalink)
Member: 1789946
Thanks Meter: 6
new generation of ipad , supported hardware icloud remove ?
hi please
i want to know , ipad air 3 A2153, its supported for icloud remove with hardware?, remove nand and write new SN ? thanks to answer me, same question for ipad 7th, and ipad pro 3th generation and 4th
thank younw
The Following User Says Thank You to racim-isn0w For This Useful Post:
Old 06-26-2020, 08:00   #2 (permalink)
Miluk's Avatar
Member: 384541
Thanks Meter: 100
All are supported.
Wysłane z mojego Pixel 3 przy użyciu Tapatalka
Old 06-26-2020, 08:59   #3 (permalink)
Member: 1964660
Thanks Meter: 54
IPad pro 3 don't supported, no serial numbers
Old 06-26-2020, 13:36   #4 (permalink)
Member: 1789946
Thanks Meter: 6
and ipad air 3 ? and ipad 7th gen ?
and if ipad pro 3th gen comes without SN, his activation on apple serveur with ??
thank you
Old 06-27-2020, 20:30   #5 (permalink)
Zaki Bouzidson's Avatar
Member: 2287326
Thanks Meter: 47
iPad Air 3 needs BGA 110 slot to read NAND (like iPhone 8 & up)
Old 06-29-2020, 01:00   #6 (permalink)
Member: 1789946
Thanks Meter: 6
its work with JC MODULE NAND READ/WRITE PROGRAMMER FOR IPHONE 8/8P/X ???
i can buy any SN ? like SN for A8 , its work with it ?
Old 07-01-2020, 21:56   #7 (permalink)
Member: 2277735
Thanks Meter: 214
I activated an a4 serial on a8 device on latest OS yesterday so even pro second gen should activate iPad 3rd gen
Old 07-03-2020, 01:42   #8 (permalink)
Member: 2287326
Thanks Meter: 47
Sorry Iím late, to make it clear.. the iPad Air 3 you mentioned above is the [cellular] version. And since I havenít found any schematics for this model I cannot tell you where the ĎBoard_IDí resistor is in order to convert it FIRST to a [WiFi only] iPad & then program the NAND. Hope that answers the question.
As long as you program the serial number along with the linked Wifi and BT addresses, Yes.
Old 10-27-2020, 03:12   #9 (permalink)
Member: 2970811
Thanks Meter: 5
i have ipad mini 3 A1600. i remove resistor to change to wifi only. i remove nand to reprog. but when i restore i get error 4014? any one can help?
Old 11-09-2020, 00:15   #10 (permalink)
Member: 1658652
Thanks Meter: 9
No There is no solution for A12 DEVICES guys. Ipad mini 5 and ipad air 3 and above cant be activated. I have already tried every combination, hope this helps.
The Following 2 Users Say Thank You to alkhan22 For This Useful Post:
Old 11-09-2020, 05:46   #11 (permalink)
Member: 2790571
Thanks Meter: 6
Currently, some iPad models in iOS 14.1 cannot be activated by changing the serial number, such as iPad9.7 ipad6 mini4
Old 11-10-2020, 08:48   #12 (permalink)
Member: 1471673
Thanks Meter: 6
Yes they can, no problems at all.
Old 11-14-2020, 06:38   #13 (permalink)
Member: 2970811
Thanks Meter: 5
i heard apple has blocked icl0ud hardware method. is this true?
Old 11-15-2020, 11:58   #14 (permalink)
Member: 1658652
Thanks Meter: 9
Yes alot of devices cant be activated now. may be in few days or month time all will be blocked. No more icloud removal i guess
Old 11-17-2020, 21:09   #15 (permalink)
Member: 2287326
Thanks Meter: 47
I did an iPad (6) two weeks ago without a problem I don’t think there’s anything wrong!!
If so, show the proof! what’s the error message? what are the symptoms?
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.17738 seconds with 7 queries
