Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-04-2021, 07:45   #1 (permalink)
Member: 2681265
Thanks Meter: 97
PanicFull/Analytics/Error/
When restarting the iPhone / iPad, to make it easier to do diagnostics and not to solder everything, go to Settings-Privacy-Analytics and improvements-Analytics data-find the record of the last reboot and look for keywords in it. Mostly in the logs there are abbreviations such as prs (pressure), mic (microphone), ALS (Ambient Light Sensor),... Records of lines and elements from diagrams are also common, so if you do not find something from my records, you can turn on your wit yourself and try to decipher this or that log. Keep in mind that the log may not be written or not completely written, try to wait for another reboot and watch the log. I will keep updating these records. PRO-mobile, Telegram @iKolhoznik.
"AOP PANIC - PressureController" - Barometer
This error occurs mainly on iPh X and above, there is a barometer on the system cable at the bottom near the left microphone.
"ANS / ANS2" - NAND
Mostly due to NAND, but look for keywords in the logs.
“SD: 0 Missing sensor (s): TG0B” - battery / TIGRIS
The device does not see the battery.
“AOP PANIC - SCMto: 0 – prox” - PROXIMITY
A proximity sensor, usually after water, causes the phone to reboot.
"Kernel data abort" - CPU
Mainly because of the processor blade or the coils along the buck lines. Also in the log, there are sometimes specific lines and elements from the diagrams.
“Missing sensor (s): mic1” - Microphone
Often after water or mechanical stress.
mic1 is the bottom left microphone.
mic2 - next to the flash / flashlight.
mic3 - next to the front camera.
mic4 is the bottom right microphone.
“SD: 1 Missing sensor (s): Prs0” - Barometer
The barometer is damaged or its line.
"AppleSocHot: hot hot hot" - CPU / CP
Met only on iPhone 7 models.
Mainly because of the CP, but I also met a break along the AP_TO_PMU_SOCHOT_L line from the CPU to the CP.
“L2C / LLC” - North amplifier
Met on many models, sometimes there is a problem in the front loop and the punched LX coil for sound amplification.
"Prev-next / LSU" - Quartz clock generator
Only met on iPhone 5c.
“NO pulse on” - Taptic Engine
Often the connector is corroded.
“Nvme” - NAND
Nand with PCIE bus.
“Lm3539" - Backlight Driver
On Plus models, to find out which of the two, look in the log for the i2c line.
“Mic-temp-sens2" - mic2
Microphone next to flash / flashlight. Often found on iPhone 11.
"Kernel instructglon fetch Abort" - CPU
Termination of the CPU core.
“SCL display PMU” - Image driver
“GFX GPU” - CPU
Cessation of the CPU, only met on iPhone 8 models, often due to words in the board.
“H3K5 Tglon” - Audio Codec / Amplifiers
“SMC PANIC ASSERTION” - Processor / Top Board
Met on iPhone X and above models.
“SEP ROM to glon SMC DATA ABORT” - CPU
It can also be any item that has certificates.
“EMemory apcie” - NAND
“CP_COM_NORM REQUEST” - CPU / NAND / CAMERA
Ambiguous error, search the log for more keywords.
“Dart-dispo SMMU error” - Main camera
"Firmware fatal" - software
The flashing helps.
“Initproc exited” - Crystal Oscillator
“Invaild queue element linkage” - NAND
"AGXG10P BO NMI" - Failure of layers in the board
Punched sleeves / bushings.
"Apple tristar2" - Tristar "
Charge controller or its lines between the tiger and tristar.
“PMP NMI FIQ power (1) -failed to transition” - CPU / coils / KP
Ambiguous error.
"Void applesynopsysMIPID SIC glontroller" - Front ribbon cable
“AppleBCMWLAN” - WF / BT
“AOP PANIC” - Ambiguous error, look for keywords in the log.
"Ememory" - Nand
Mostly on iPhone 5s / 6.
“Anc-postnand.c1260 asser failed link” - Nand
“Stacks + routined” - battery
Found mainly on iPad.
"AGXK AGXAcceletor" - Gyroscope / Accelerometer
“Apcie (0: s3e)” - NAND
“Apcie (wlan)” - WF
“Apcie (bt)” - BT
“Sleep \ wake hang detected” - WF / codec / amplifiers
Ambiguous error freezing in sleep mode, look for keywords in the log.
“WKDMD ERROR code 0x2” - Memory error
Get Error 14 (APFS) on firmware,
"Apple PPM" - Lightning / Tristar / Tigris
The error occurs while charging.
Sorry my bad eng
The Following 31 Users Say Thank You to PRO-mobile For This Useful Post:
Old 02-04-2021, 11:24   #2 (permalink)
Member: 549849
Thanks Meter: 20
The Following 3 Users Say Thank You to muharrem şen For This Useful Post:
Old 09-07-2021, 15:25   #3 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
and what about TG0V and TP2C?
The Following 2 Users Say Thank You to ninos22 For This Useful Post:
Old 09-10-2021, 16:02   #4 (permalink)
Member: 2681265
Thanks Meter: 97
Charging port flex/power button flex/NTC
The Following 3 Users Say Thank You to PRO-mobile For This Useful Post:
Old 02-19-2022, 14:46   #5 (permalink)
Member: 255468
Thanks Meter: 3
hi dear
iphone 11 pro max reset every 24 hours
panic log :
panic(cpu 1 caller 0xfffffff01ebadd90): GFX NMI: GFXEndpoint2: send msg=0x83000000000008 error=0xe00002db
RTBuddy(AP): Debug info:
_iopStatus = 0x8001
_powerStateChangeInProgress = false
Mailbox Status:
IDLE_STATUS: 0x00000000
MAILBOX_SET: 0x00000000
MAILBOX_CLR: 0x00000000
INBOX_CTRL: 0x00500501
OUTBOX_CTRL: 0x00027701
AP->IOP Mailbox Log:
Timestamp | Dir | Message
0x00000000b5512aec | [RX] | Interrupt
0x00000000b5512b08 | [RX] | 0x0042000000000000 0x0010ef0000000020
0x00000000b5513c44 | [RX] | Interrupt
0x00000000b5513c64 | [RX] | 0x0042000000000000 0x0010f00000000020
0x00000000b5514218 | [RX] | Interrupt
The Following 2 Users Say Thank You to aja645 For This Useful Post:
Old 04-04-2022, 18:30   #6 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 252
anyone fixed missing sensor TQ0Q? iphone 8 plus qualcom
The Following 4 Users Say Thank You to simpleprince49 For This Useful Post:
Old 04-06-2022, 06:10   #7 (permalink)
Member: 2681265
Thanks Meter: 97
Niki (m5500).
Old 04-06-2022, 06:12   #8 (permalink)
Member: 2681265
Thanks Meter: 97
Originally Posted by aja645 View Post
hi dear
panic log :
_iopStatus = 0x8001
Mailbox Status:
GFX (Graphics) NMI (NonMaskableInterrupt) - reball CPU.
Old 06-18-2022, 13:38   #9 (permalink)
Member: 2078322
Thanks Meter: 3
missing sensor=missing sensor
tp3r=lower layer fault/fit short circuit
tgob=battery data
prs0=tail plug
mic1=tail plug microphone
mic2=power-on cable microphone
The Following 3 Users Say Thank You to mouhamadk For This Useful Post:
Old 08-16-2022, 16:23   #10 (permalink)
bobo bokota's Avatar
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 494
"date"
: "2022-08-16 15:31:36.72+0100",
"panicString"
"panic(cpu 2 caller Oxfffffff024cf7564): "Timing out on commit.
Waited 5 s. KSWMPR _INTERRUPT AP:0x0|"
@AppleSynopsysMIPIDSIController.cpp:842|nDebuggerm essageanic|nMemory
ID: 0x1|nOS release type: User\nOS version: 19F77|nKernel version: Darwin Kernel
Version 21.5.0: Thu Apr 21 21:51:27 PDT 2022; root:xnu-8020.122.1-1V
RELEASE ARM64 T8030 nKernel UUID: CBEE5FC1-AA34-347C-
16:15
panic-full-2022-08-16-153136.000.
"kerne)" : "Darwin Kernel Version 21.5.0: Thu Apr 21 21:51:27 PDT 2022;
root:xnu-8020.122.1-1VRELEASE_ARM64_T8030",
"incident":"D1DDC79E-ODCC-487E-ACA5-9C6897D282F0"
"crashReporterKey":"c95e63431a121c8c5b8c55a64c36d8 939dc2e7b2",
"date"
"panicString"
B2F9-97D8B90ADF86|niBoot version: iBoot-7459.120.62.0.3lnsecure boot?:
YES|nPaniclog version: 13InKernel slide:
x000000001bdb4000lnKernel text
base: Oxfffffff022db8000jnmach_absolute_time: 0x84825d78e|nEpoch Time:
sec
usec|n Boot
Ox62fba46b 0x0000132eln Sleep:0x00000000
0x00000000\n Wake
: Ox00000000 0x00000000ln Calendar:0x62fbaa2c
0x00070e4d\n|nZone info:\n Zone map: Oxffffffe700444000 -
Oxffffffed00444000 n VM
Oxffffffe700444000 - Oxffffffe7e6aa8000 n
RO : Oxffffffe7e6aa8000 - Oxffffffe833774000 n
GENO:Oxffffffe833774000
Oxffffffe919dd8000 n
GEN1: Oxffffffe919dd8000 -Oxffffffea0043c000\n
GEN2: Oxffffffea0043c000 - Oxffffffeae6aa4000 n
GEN3: Oxffffffeae6aa4000
- Oxffffffebcd10c000 n
DATA Oxffffffebcd10c000 - Oxffffffed00444000 n
Metadata: Oxffffffe6fd6e0000 - Oxffffffe6feee0000|n Bitmaps
Oxffffffe6feee0000 - Oxffffffe700434000\n\nCORE O recently retired instr at
Oxfffffff023a677c8 nCORE1 recently retired instr at Oxfffffff023a677c8 nCORE 2
recently retired instr at Oxfffffff023a66328\CORE 3 recently retired instr at
Oxfffffff023a677c8|CORE 4 recently retired instr at Oxfffffff023a677cclnCORE 5
recently retired instr a Oxfffffff023a677cclnCORE O: PC=0xfffffff0259a8668
LR-Oxfffffff023a5bb7c,FP=Oxffffffed1274baa0(nCORE1:PC =0xfffffff023953fb8,
LR-0xfffffff023953fb8 FP=Oxffffffed127bbf00|nCORE2 is the one that panicked
Check the full backtrace for details. InCORE 3: PC=0xfffffff023953fb8,
LR=0xfffffff023953fb8,FP=Oxffffffed128cbf00\nCORE4 :PC=0xfffffff023953fb8,
LR=0xfffffff023953fb8,FP=0xffffffed12a0bf00|nCORE5 :PC=0xfffffff023953fb8,
LR=0xfffffff023953fb8FP=Oxffffffed1257bf00|nCompre ssorInfo:0%of.
compressed pages limit (OK) and 0% of segments limit (OK) with 1 swapfiles and
OK swap space\nPanicked task Oxffffffe91abd6670: 4346 pages, 23 threads: pid
66: backboardd\nPanicked thread: Oxffffffe9fee12940, backtrace:
Oxffffffed1269b110, tid:14950(n|t\tIr:Oxfffffff02392072cfo:
oxffffffed1269b150\nitit Ir: Oxfffffff023920444 fp: Oxffffffed1269b1c0 nlt)t Ir:
Oxfffffff023a6e6c4 fp:Oxffffffed1269ble0\n|t|tIr:Oxfffffff023a5f460fp :
Oxffffffed1269b250\nltitIr:Oxfffffff023a5e2dcfp:Ox ffffffed12696310(nltitIr:
Oxfffffff024064610 fp:Oxffffffed1269b320\n|tItIr:Oxfffffff023920120fp :
Oxffffffed1269b6b0|n|tt Ir: Oxfffffff023920120 fp: Oxffffffed12696710 nltit Ir:
Oxfffffff0259a7fb4 fp:Oxffffffed1269b730|nlt\tIr:Oxfffffff024cf7564fp :
Oxffffffed1269b760\n|tt Ir: Oxfffffff024cf3728 fp: Oxffffffed12696790 nitit Ir:
Oxfffffff023f864bc fp:Oxffffffed1269b800\nitItIr:Oxfffffff024cf5a8cfp :
oxffffffed1269b830|n|tt Ir: Oxfffffff024cf2808 fp: Oxffffffed12696870 n|t|t Ir:
Oxfffffff023f864bc fp:Oxffffffed1269b8e0|n|titIr:Oxfffffff024cf5664fp :
Oxffffffed1269b910\n|t)t Ir: Oxfffffff0257eb130 fp: Oxffffffed1269b950 nitit Ir:
Oxfffffff0240c44e8 fp:Oxffffffed1269b9d0\n|tItIr:Oxfffffff0240c331cfp :
Oxffffffed1269baf0|n|t\tIr: Oxfffffff023f864bc fp: Oxffffffed1269bb60\n|t|t Ir:
Oxfffffff023fd1b44 fp:Oxffffffed1269bbc0\ntItIr:Oxfffffff023a2f178fp:
Oxffffffed1269bbfOln|t)t Ir: Oxfffffff023927640 fp: Oxffffffed1269bc90 nitit Ir:
Oxfffffff0238f5468 fp:Oxffffffed1269bcfO|n|tItIr:Oxfffffff02390ff6cfp :
Oxffffffed1269bd80\n|t\t Ir: Oxfffffff023a52ae0 fp: Oxffffffed1269be50\nitit Ir:
Oxfffffff023a5e624 fp:Oxffffffed1269bf10|n|tltIr:Oxfffffff024064610fp :
Oxffffffed1269bf20 nln"
"panicFlags":"0x802"
"otherString" : "In** Stackshot Succeeded ** Bytes Traced 216462
(Uncompressed 558880) **In"
"memoryStatus"
("compressorSize":325,'compressions":4388,"decompr essions":2080,"busyBuffer
Count":0,"memoryPressureDetails":
("pagesWanted":163,"pagesReclaimed":0)"pageSize":1 6384"memoryPressure":fal
se,"memoryPages":
("active":92799,"throttled":0,"fileBacked":79658," wired":41579,"purgeable":4271,
active:91322 free":1837
Old 08-18-2022, 16:37   #11 (permalink)
Member: 2681265
Thanks Meter: 97
Originally Posted by bobo bokota View Post
"date"
"panicString"
16:15
"date"
"panicString"
sec
usec|n Boot
0x00000000\n Wake
"memoryStatus"
se,"memoryPages":
AppleSynopsysMIPIDSIController - the controller is on the display itself. Either change the display or the chip itself
Old 09-05-2022, 18:56   #12 (permalink)
Member: 2148606
Sonork: Bobobokota
Thanks Meter: 494
"panicString" : "panic (cpu 5 caller Oxfffffff01f5083cc) : l"AppleSocHot: Hot Hot
Hot (89500DCCV5518 89500DCCV/5518 094COD9EVO 89310E32V5678
894E0DD8V5537 88FE0F4BV6117 89260E6FV5773 854621B3V13479 89310E32V
(5678, Ids37V10V49V40V13V5V1V0V2, Perf100V100)|"
@AppleSocHot.cpp:608\nDebugger message: panic\nMemory ID: 0x6|nOS release
type: User\nOS version: 19G71\nKernel version: Darwin Kernel Version 21.6.0: Sat
Jun18 18:56:54 PDT2022; root:xnu-8020.140.41-4V
RELEASE_ARM64_T8020|nKernelUUID:7A97AA40-5539-3EFC-9986-
Old 09-09-2022, 18:16   #13 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 261
I use this software for decrypt panic log crash. Connect iPhone to pc and read log, software shows probably problem.
https://github.com/waynebonc/iDeviceLogAnalyzer-public
The Following 3 Users Say Thank You to orangade For This Useful Post:
Old 09-12-2022, 08:00   #14 (permalink)
Member: 2681265
Thanks Meter: 97
"AppleSocHot: hot hot hot" - CPU/PMU
Mainly because of the PMU, but I also met a break along the AP_TO_PMU_SOCHOT_L line from the CPU to the PMU.
The Following User Says Thank You to PRO-mobile For This Useful Post:
Old 09-12-2022, 19:12   #15 (permalink)
Member: 975554
Thanks Meter: 252
also met in xr
i have this also in xr then i change the coil that connects this line from pmu to cpu then its fixed
The Following User Says Thank You to simpleprince49 For This Useful Post:
Page generated in 0.30741 seconds with 9 queries
