Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2017 Location: Russia - Izhevsk
Member: 2681265 Status: Offline Thanks Meter: 86 | PanicFull/Analytics/Error/ "AOP PANIC - PressureController" - Barometer This error occurs mainly on iPh X and above, there is a barometer on the system cable at the bottom near the left microphone. "ANS / ANS2" - NAND Mostly due to NAND, but look for keywords in the logs. “SD: 0 Missing sensor (s): TG0B” - battery / TIGRIS The device does not see the battery. “AOP PANIC - SCMto: 0 – prox” - PROXIMITY A proximity sensor, usually after water, causes the phone to reboot. "Kernel data abort" - CPU Mainly because of the processor blade or the coils along the buck lines. Also in the log, there are sometimes specific lines and elements from the diagrams. “Missing sensor (s): mic1” - Microphone Often after water or mechanical stress. mic1 is the bottom left microphone. mic2 - next to the flash / flashlight. mic3 - next to the front camera. mic4 is the bottom right microphone. “SD: 1 Missing sensor (s): Prs0” - Barometer The barometer is damaged or its line. "AppleSocHot: hot hot hot" - CPU / CP Met only on iPhone 7 models. Mainly because of the CP, but I also met a break along the AP_TO_PMU_SOCHOT_L line from the CPU to the CP. “L2C / LLC” - North amplifier Met on many models, sometimes there is a problem in the front loop and the punched LX coil for sound amplification. "Prev-next / LSU" - Quartz clock generator Only met on iPhone 5c. “NO pulse on” - Taptic Engine Often the connector is corroded. “Nvme” - NAND Nand with PCIE bus. “Lm3539" - Backlight Driver On Plus models, to find out which of the two, look in the log for the i2c line. “Mic-temp-sens2" - mic2 Microphone next to flash / flashlight. Often found on iPhone 11. "Kernel instructglon fetch Abort" - CPU Termination of the CPU core. “SCL display PMU” - Image driver “GFX GPU” - CPU Cessation of the CPU, only met on iPhone 8 models, often due to words in the board. “H3K5 Tglon” - Audio Codec / Amplifiers “SMC PANIC ASSERTION” - Processor / Top Board Met on iPhone X and above models. “SEP ROM to glon SMC DATA ABORT” - CPU It can also be any item that has certificates. “EMemory apcie” - NAND “CP_COM_NORM REQUEST” - CPU / NAND / CAMERA Ambiguous error, search the log for more keywords. “Dart-dispo SMMU error” - Main camera "Firmware fatal" - software The flashing helps. “Initproc exited” - Crystal Oscillator “Invaild queue element linkage” - NAND "AGXG10P BO NMI" - Failure of layers in the board Punched sleeves / bushings. "Apple tristar2" - Tristar " Charge controller or its lines between the tiger and tristar. “PMP NMI FIQ power (1) -failed to transition” - CPU / coils / KP Ambiguous error. "Void applesynopsysMIPID SIC glontroller" - Front ribbon cable “AppleBCMWLAN” - WF / BT “AOP PANIC” - Ambiguous error, look for keywords in the log. "Ememory" - Nand Mostly on iPhone 5s / 6. “Anc-postnand.c1260 asser failed link” - Nand “Stacks + routined” - battery Found mainly on iPad. "AGXK AGXAcceletor" - Gyroscope / Accelerometer “Apcie (0: s3e)” - NAND “Apcie (wlan)” - WF “Apcie (bt)” - BT “Sleep \ wake hang detected” - WF / codec / amplifiers Ambiguous error freezing in sleep mode, look for keywords in the log. “WKDMD ERROR code 0x2” - Memory error Get Error 14 (APFS) on firmware, "Apple PPM" - Lightning / Tristar / Tigris The error occurs while charging. Sorry my bad eng ![]() |
The Following 29 Users Say Thank You to PRO-mobile For This Useful Post: |
![]() | #5 (permalink) |
Junior Member ![]() Join Date: Apr 2006
Member: 255468 Status: Offline Thanks Meter: 2 | hi dear iphone 11 pro max reset every 24 hours panic log : panic(cpu 1 caller 0xfffffff01ebadd90): GFX NMI: GFXEndpoint2: send msg=0x83000000000008 error=0xe00002db RTBuddy(AP): Debug info: _iopStatus = 0x8001 _powerStateChangeInProgress = false Mailbox Status: IDLE_STATUS: 0x00000000 MAILBOX_SET: 0x00000000 MAILBOX_CLR: 0x00000000 INBOX_CTRL: 0x00500501 OUTBOX_CTRL: 0x00027701 AP->IOP Mailbox Log: Timestamp | Dir | Message 0x00000000b5512aec | [RX] | Interrupt 0x00000000b5512b08 | [RX] | 0x0042000000000000 0x0010ef0000000020 0x00000000b5513c44 | [RX] | Interrupt 0x00000000b5513c64 | [RX] | 0x0042000000000000 0x0010f00000000020 0x00000000b5514218 | [RX] | Interrupt |
The Following User Says Thank You to aja645 For This Useful Post: |
![]() | #6 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 234 ![]() | anyone fixed missing sensor TQ0Q? iphone 8 plus qualcom |
The Following 2 Users Say Thank You to simpleprince49 For This Useful Post: |
![]() | #8 (permalink) | |
Member: 2681265 Status: Offline Thanks Meter: 86 | Quote:
The Following User Says Thank You to PRO-mobile For This Useful Post: |
![]() | #9 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2078322 Status: Offline Thanks Meter: 2 | missing sensor=missing sensor tp3r=lower layer fault/fit short circuit tgob=battery data prs0=tail plug mic1=tail plug microphone mic2=power-on cable microphone |
The Following 2 Users Say Thank You to mouhamadk For This Useful Post: |
![]() | #10 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 462 ![]() | "date" : "2022-08-16 15:31:36.72+0100", "panicString" "panic(cpu 2 caller Oxfffffff024cf7564): "Timing out on commit. Waited 5 s. KSWMPR _INTERRUPT AP:0x0|" @AppleSynopsysMIPIDSIController.cpp:842|nDebuggerm essage ![]() ID: 0x1|nOS release type: User\nOS version: 19F77|nKernel version: Darwin Kernel Version 21.5.0: Thu Apr 21 21:51:27 PDT 2022; root:xnu-8020.122.1-1V RELEASE ARM64 T8030 nKernel UUID: CBEE5FC1-AA34-347C- = 16:15 ( panic-full-2022-08-16-153136.000. "kerne)" : "Darwin Kernel Version 21.5.0: Thu Apr 21 21:51:27 PDT 2022; root:xnu-8020.122.1-1VRELEASE_ARM64_T8030", "incident":"D1DDC79E-ODCC-487E-ACA5-9C6897D282F0" "crashReporterKey":"c95e63431a121c8c5b8c55a64c36d8 939dc2e7b2", "date" : "2022-08-16 15:31:36.72+0100", "panicString" "panic(cpu 2 caller Oxfffffff024cf7564): "Timing out on commit. Waited 5 s. KSWMPR _INTERRUPT AP:0x0|" @AppleSynopsysMIPIDSIController.cpp:842|nDebuggerm essage ![]() ID: 0x1|nOS release type: User\nOS version: 19F77|nKernel version: Darwin Kernel Version 21.5.0: Thu Apr 21 21:51:27 PDT 2022; root:xnu-8020.122.1-1V RELEASE ARM64 T8030 nKernel UUID: CBEE5FC1-AA34-347C- B2F9-97D8B90ADF86|niBoot version: iBoot-7459.120.62.0.3lnsecure boot?: YES|nPaniclog version: 13InKernel slide: x000000001bdb4000lnKernel text base: Oxfffffff022db8000jnmach_absolute_time: 0x84825d78e|nEpoch Time: sec usec|n Boot Ox62fba46b 0x0000132eln Sleep:0x00000000 0x00000000\n Wake : Ox00000000 0x00000000ln Calendar:0x62fbaa2c 0x00070e4d\n|nZone info:\n Zone map: Oxffffffe700444000 - Oxffffffed00444000 n VM Oxffffffe700444000 - Oxffffffe7e6aa8000 n RO : Oxffffffe7e6aa8000 - Oxffffffe833774000 n GENO:Oxffffffe833774000 Oxffffffe919dd8000 n GEN1: Oxffffffe919dd8000 -Oxffffffea0043c000\n GEN2: Oxffffffea0043c000 - Oxffffffeae6aa4000 n GEN3: Oxffffffeae6aa4000 - Oxffffffebcd10c000 n DATA Oxffffffebcd10c000 - Oxffffffed00444000 n Metadata: Oxffffffe6fd6e0000 - Oxffffffe6feee0000|n Bitmaps Oxffffffe6feee0000 - Oxffffffe700434000\n\nCORE O recently retired instr at Oxfffffff023a677c8 nCORE1 recently retired instr at Oxfffffff023a677c8 nCORE 2 recently retired instr at Oxfffffff023a66328\CORE 3 recently retired instr at Oxfffffff023a677c8|CORE 4 recently retired instr at Oxfffffff023a677cclnCORE 5 recently retired instr a Oxfffffff023a677cclnCORE O: PC=0xfffffff0259a8668 LR-Oxfffffff023a5bb7c,FP=Oxffffffed1274baa0(nCORE1:PC =0xfffffff023953fb8, LR-0xfffffff023953fb8 FP=Oxffffffed127bbf00|nCORE2 is the one that panicked Check the full backtrace for details. InCORE 3: PC=0xfffffff023953fb8, LR=0xfffffff023953fb8,FP=Oxffffffed128cbf00\nCORE4 :PC=0xfffffff023953fb8, LR=0xfffffff023953fb8,FP=0xffffffed12a0bf00|nCORE5 :PC=0xfffffff023953fb8, LR=0xfffffff023953fb8FP=Oxffffffed1257bf00|nCompre ssorInfo:0%of. compressed pages limit (OK) and 0% of segments limit (OK) with 1 swapfiles and OK swap space\nPanicked task Oxffffffe91abd6670: 4346 pages, 23 threads: pid 66: backboardd\nPanicked thread: Oxffffffe9fee12940, backtrace: Oxffffffed1269b110, tid:14950(n|t\tIr:Oxfffffff02392072cfo: oxffffffed1269b150\nitit Ir: Oxfffffff023920444 fp: Oxffffffed1269b1c0 nlt)t Ir: Oxfffffff023a6e6c4 fp:Oxffffffed1269ble0\n|t|tIr:Oxfffffff023a5f460fp : Oxffffffed1269b250\nltitIr:Oxfffffff023a5e2dcfp:Ox ffffffed12696310(nltitIr: Oxfffffff024064610 fp:Oxffffffed1269b320\n|tItIr:Oxfffffff023920120fp : Oxffffffed1269b6b0|n|tt Ir: Oxfffffff023920120 fp: Oxffffffed12696710 nltit Ir: Oxfffffff0259a7fb4 fp:Oxffffffed1269b730|nlt\tIr:Oxfffffff024cf7564fp : Oxffffffed1269b760\n|tt Ir: Oxfffffff024cf3728 fp: Oxffffffed12696790 nitit Ir: Oxfffffff023f864bc fp:Oxffffffed1269b800\nitItIr:Oxfffffff024cf5a8cfp : oxffffffed1269b830|n|tt Ir: Oxfffffff024cf2808 fp: Oxffffffed12696870 n|t|t Ir: Oxfffffff023f864bc fp:Oxffffffed1269b8e0|n|titIr:Oxfffffff024cf5664fp : Oxffffffed1269b910\n|t)t Ir: Oxfffffff0257eb130 fp: Oxffffffed1269b950 nitit Ir: Oxfffffff0240c44e8 fp:Oxffffffed1269b9d0\n|tItIr:Oxfffffff0240c331cfp : Oxffffffed1269baf0|n|t\tIr: Oxfffffff023f864bc fp: Oxffffffed1269bb60\n|t|t Ir: Oxfffffff023fd1b44 fp:Oxffffffed1269bbc0\ntItIr:Oxfffffff023a2f178fp: Oxffffffed1269bbfOln|t)t Ir: Oxfffffff023927640 fp: Oxffffffed1269bc90 nitit Ir: Oxfffffff0238f5468 fp:Oxffffffed1269bcfO|n|tItIr:Oxfffffff02390ff6cfp : Oxffffffed1269bd80\n|t\t Ir: Oxfffffff023a52ae0 fp: Oxffffffed1269be50\nitit Ir: Oxfffffff023a5e624 fp:Oxffffffed1269bf10|n|tltIr:Oxfffffff024064610fp : Oxffffffed1269bf20 nln" "panicFlags":"0x802" "otherString" : "In** Stackshot Succeeded ** Bytes Traced 216462 (Uncompressed 558880) **In" "memoryStatus" ("compressorSize":325,'compressions":4388,"decompr essions":2080,"busyBuffer Count":0,"memoryPressureDetails": ("pagesWanted":163,"pagesReclaimed":0)"pageSize":1 6384"memoryPressure":fal se,"memoryPages": ("active":92799,"throttled":0,"fileBacked":79658," wired":41579,"purgeable":4271, active:91322 free":1837 |
![]() | #11 (permalink) | |
![]() | #12 (permalink) |
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 462 ![]() | "panicString" : "panic (cpu 5 caller Oxfffffff01f5083cc) : l"AppleSocHot: Hot Hot Hot (89500DCCV5518 89500DCCV/5518 094COD9EVO 89310E32V5678 894E0DD8V5537 88FE0F4BV6117 89260E6FV5773 854621B3V13479 89310E32V (5678, Ids37V10V49V40V13V5V1V0V2, Perf100V100)|" @AppleSocHot.cpp:608\nDebugger message: panic\nMemory ID: 0x6|nOS release type: User\nOS version: 19G71\nKernel version: Darwin Kernel Version 21.6.0: Sat Jun18 18:56:54 PDT2022; root:xnu-8020.140.41-4V RELEASE_ARM64_T8020|nKernelUUID:7A97AA40-5539-3EFC-9986- |
![]() | #13 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2007 Location: France 72,77
Member: 521955 Status: Offline Thanks Meter: 231 | I use this software for decrypt panic log crash. Connect iPhone to pc and read log, software shows probably problem. https://github.com/waynebonc/iDeviceLogAnalyzer-public ![]() |
The Following 2 Users Say Thank You to orangade For This Useful Post: |
![]() | #14 (permalink) | |
Met only on iPhone 7 models. Mainly because of the PMU, but I also met a break along the AP_TO_PMU_SOCHOT_L line from the CPU to the PMU. | |
![]() | #15 (permalink) | |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 234 ![]() | also met in xr Quote:
i have this also in xr then i change the coil that connects this line from pmu to cpu then its fixed | |
The Following User Says Thank You to simpleprince49 For This Useful Post: |
