mastro7712 | 07-24-2014 15:54 | Quote:
Originally Posted by laptopmd
(Post 10455650)
I will look at the picture at home this afternoon.
What is the main problem of your phone ? Touch not working ?
It was dropped ? Water damaged ?
Does it charge the battery ? | The touch doesn't work!! no water !! no dropped!! battery charge!! only that during a clumsy attempt to replace the battery, the guy from whom I bought, has damaged the two central tracks of the battery connector, then I've done jumpers between C300 and second pin battery connector and between the third pin C293 battery as specified in the schema of Wites (the battery and charge the iphone work perfectly!!!). The only problem is that in my logic board lacked C293 component and I did the same the jumper even though it lacked the component .... I made a mistake!? This error can jeopardize the smooth operation of touch!? I read on another forum user who had my same problem and solved re-attaching the third pin of the battery was bad soldered!! isn't that maybe it could also be my case!? help me to do some test!?!?
Thanks a lot my friend!!!
look the photos i tink very important!! :-) :-) |
