Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-18-2011, 21:51   #166 (permalink)
Member: 1631564
Hallo,
what ist this for a part in the near of docconnector? could i make i jumper ?
this phone 3gs not charge and not recognized to itunes!
http://img29.imageshack.us/img29/5471/iphpne3gsdoc.jpg
thanks a lot
Old 09-19-2011, 12:15   #167 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,595
Originally Posted by norin32 View Post
Hallo,
thanks a lot
This is resistor 100k you need to solder same,you can find this resistor in other phones like Sony Ericsson,Nokia,Samsung etc.
Old 09-19-2011, 12:23   #168 (permalink)
Member: 1017374
Thanks Meter: 2,595
Originally Posted by GhostDawgg View Post
OK! Did ALL that pc would let me download, and STILL NO LUCK! Used several programs but NONE kicked iphone out of DFU mode. So what now? used umbrella, shift + restore but it keeps asken for a restore file.....................
now what?!?
Bro if phone in dfu mode you need to remove battery then put back.
If it ask for a restore file first download from internet what ios you want to install,then show where is located.
Old 09-19-2011, 12:27   #169 (permalink)
Member: 1017374
Thanks Meter: 2,595
my 3gs have no wifi i cannot activated tihs in the settings is it a hardware problem?
there is no buttom to activated this can i do anything to fix it ?
ImageShack® - Online Photo and Video Hosting
Try restore firmware with itunes if not help,problem might be hardware.
To find if problem hardware or software use iRecovery.
Old 09-19-2011, 12:33   #170 (permalink)
Member: 1017374
Thanks Meter: 2,595
Originally Posted by iphone4fanatic View Post
Hi, Anyone got a clus for the above problem, help would be highly apprecaited. Thanks.
Try other battery,check GAS GAUGE pin on flex if not damaged.
Old 09-19-2011, 17:36   #171 (permalink)
Member: 1657854
Hi i am using iphone 3gs, i got a problem with my phone my phone was not turning on, i have replaced a new battery then it worked fine but when i plugged it for charging aging it switched off.. same thing repeated for another battery..can you tell me any solution for this problem with my phone.
Old 09-19-2011, 22:50   #172 (permalink)
Member: 1631564
Irecovery not works
can i use other software ?
Old 09-20-2011, 03:50   #173 (permalink)
Member: 1658134
Hi im from Australia and i have an iphone 4 version 4.33 a few months ago when i moved out of home i thought lost it in the moving process so i had my insurance replace it with a new one, anyway it's been 3 months and it has been found at my parents house where i moved from but is now locked by imei. is there anyway i can get this fixed without giving it back to telstra?
Old 09-20-2011, 10:55   #174 (permalink)
Member: 1017374
Thanks Meter: 2,595
Irecovery not works
You need to install Visual C++ 2008 and libusb driver to get it work go here [Answer] For those who can't get the iRecovery to work! - iPad, iPhone, and iPod touch forums - iFans
Old 09-20-2011, 10:58   #175 (permalink)
Member: 1017374
Thanks Meter: 2,595
There is shorting something,your charger or your phone first try other original
charger & post result.
Old 09-21-2011, 15:23   #176 (permalink)
Member: 1427312
I have 4 different iphone 3G - each has own problem, takes so much time to repair and so much knowledge - I can't even begin to fix it. Can anyone from this thread with qualified knowledge respond so i can mail you 1 phone at a time to fix ? I'm in USA. Thank you. PM me.
Old 09-21-2011, 17:36   #177 (permalink)
Member: 1186634
Thanks Meter: 11
hi senior my problem is home butten is not working i change charging cable
home butten is working but charging is not working plz send me any solution this id #[email protected]
Old 09-22-2011, 15:40   #178 (permalink)
Member: 1657854
i am charging the phone with my laptop still the problem not solved..
Old 09-22-2011, 16:27   #179 (permalink)
Member: 1017374
Thanks Meter: 2,595
I think charging pins on dock connector may short,try replace dock flex connector.
Old 09-26-2011, 03:59   #180 (permalink)
Member: 1657854
I have replaced an new doc connector but still the issue is not resolved....
Page generated in 0.26533 seconds with 10 queries
