07-30-2013, 02:51 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: u.k
Member: 467279 Status: Offline Thanks Meter: 42 | ipad mini problem have i pad mini, digitizer replaced soldering perfect but power button no work properly and touch not work, done before many successfully but this one pain in the ***** what could be wrong home button perfect on aswell home button works,perfect tried 4 digitizer same thing touch unresponsive! tried reboot and factory reset nothing aaah help pls,thanks |
07-30-2013, 03:17 | #2 (permalink) | |
Member: 467279 Status: Offline Thanks Meter: 42 | Quote:
08-09-2013, 04:01 | #4 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Toronto, Canada
Member: 1430995 Status: Offline Sonork: 100.1613203 Thanks Meter: 312 | Unplug digitizer and then check power button working or not? If yes then resolder digitizer to controller also resolder other end of controller I mean connector side that goes to motherboard. |
08-09-2013, 04:19 | #5 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | press and hold power button . see if " SLIDE TO POWER OFF " windows appear or not ? if appear, then you need to go to Settings > and change lock button / power settings. I was stressed with this issue when i did my first iPad mini. but power button can be disabled/enabled from the settings. post result of this settings first, then we move to next procedure . LITTLE MASTER |
The Following User Says Thank You to Little_Master For This Useful Post: |
11-12-2013, 08:27 | #10 (permalink) | |
Junior Member Join Date: Jul 2013
Member: 1970741 Status: Offline Thanks Meter: 1 | Quote:
Let me know if you still need help. | |
The Following User Says Thank You to comphorizons For This Useful Post: |
11-13-2013, 18:02 | #12 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Cologne, Germany Age: 38
Member: 1695725 Status: Offline Thanks Meter: 10 | Same Problem here. Thx @ little master first i thought my power button is damged. But my digitizer doesnt work...fpc connector is good, is the first digitizer i bought, maybe this one is damaged |
07-25-2014, 15:51 | #13 (permalink) |
Freak Poster Join Date: May 2012 Location: Brazil
Member: 1759455 Status: Offline Thanks Meter: 9 | any solution ? i have the same problem, touch not working, i have already tried a lot of touches but the problem is in the main board, checked filters and connector but everything is ok. |
01-09-2015, 03:01 | #15 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2110834 Status: Offline Thanks Meter: 9 | Exactly same problem here touch and power button not working. I changed the FPC connector and the bottom right last pad got lifted from the board. Please experts can you tell me solution. |
