GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   iPhone, iPad, iPod Hardware Repair (https://forum.gsmhosting.com/vbb/f631/)
-   -   Solution active ipad a1475 after hardware bypass? (https://forum.gsmhosting.com/vbb/f631/solution-active-ipad-a1475-after-hardware-bypass-3054625/)
XPTO2511 08-30-2022 11:45
Hello,
there is any solution for latest update?
When i try to active says can' conect to server....
Tanks
ackopk 09-02-2022 06:34
You have to change it to A1474, you have to remove one resistor. After that you will be able to activate it. Cellular model are not supported.
XPTO2511 09-03-2022 11:14
hello
already done that
but the problem is that shows that is not possivle to activate.
XPTO2511 12-13-2022 01:43
hello,,,,
Any solution for this?
or there is no solution yet?
tanks
ackopk 12-15-2022 07:20
Hi friend,
the only solution is to remove the resistor and change serial, bt and wifi infos. After that you have to install IOS for A1474 ipad. It works.
If you get info that it is not possible to activate that means that serial, bt and wifi infos are not ok.
SAEIDSANGAN 12-26-2022 18:03
you need change sn bt wifi address from wifi model
Page generated in 0.09863 seconds with 6 queries
