Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-30-2022, 11:45   #1 (permalink)
Member: 934255
Thanks Meter: 62
Solution active ipad a1475 after hardware bypass?
Hello,
there is any solution for latest update?
When i try to active says can' conect to server....
Tanks
Old 09-02-2022, 06:34   #2 (permalink)
Member: 2904736
Thanks Meter: 6
You have to change it to A1474, you have to remove one resistor. After that you will be able to activate it. Cellular model are not supported.
Old 09-03-2022, 11:14   #3 (permalink)
Member: 934255
Thanks Meter: 62
hello
already done that
but the problem is that shows that is not possivle to activate.
Old 12-13-2022, 01:43   #4 (permalink)
Member: 934255
Thanks Meter: 62
hello,,,,
Any solution for this?
or there is no solution yet?
tanks
Old 12-15-2022, 07:20   #5 (permalink)
Member: 2904736
Thanks Meter: 6
Hi friend,
the only solution is to remove the resistor and change serial, bt and wifi infos. After that you have to install IOS for A1474 ipad. It works.
If you get info that it is not possible to activate that means that serial, bt and wifi infos are not ok.
Old 12-26-2022, 18:03   #6 (permalink)
SAEIDSANGAN's Avatar
Member: 1691551
Sonork: 100.1622582
Thanks Meter: 53
you need change sn bt wifi address from wifi model
Page generated in 0.11336 seconds with 8 queries
