Stumped By iPhone 6 Reboot Loop Guys, I'm running into a problem with my iPhone and it seems like I've tried everything to no avail. Would really appreciate more troubleshooting ideas. I tried using the search function but I may have missed a similar thread. Phone Information
Problem Symptoms
Problem Origin
Troubleshooting
I am completely out of ideas. If you have any suggestions that may save my phone I would love to hear them; will ship beer for an idea that works! |
You need to check if you didnt damage the pcb while changing the lcd. Also you will have to check screw holes with microscope to see if you didnt make any screw damage to board layers. |
hi you problem seems to be charging ic alias U2 ( for IPH.6 <U1700>) and / or Q1701 ..replace U1700 and test starting with battery to zero charge. |
hi usb / charging IC , in your case after replace dock and battery is the successive step . Battery with quick discharge e request of to connect power charge can to be the symptom. |
Here are 3 options to fix iPhone Stuck in Boot Loop: 1. Checking the battery connector 2. Putting your iPhone into Recovery Mode 3. Upgrade and restore your iPhone with iTunes. 4. Using iMyFone iOS System Recovery. |
1- change lcd 2- change U2 IC 3- new battery Disconnect ( charger dock - all cameras cables ) Turn on I hope the BCP is fine |
iPhone Stuck in Boot Loop Quote:
Try to change tristar (u1700) it is not a charger itself, it is usb controller (and only it) |
i have same problem on a device too |
you should try the logic board in known good housing with known good battery etc , if problem persists then you have a logic board problem , check the board for visible damage under microscope , the phone is boot looping so is not getting the message to turn on tristar is the usual culprit but can be anything on that line , so change tristar which is quite a simple process then take it from there good luck |
This symptoms they refer to error 9/4013/4014 Possible i2c communication problem (CPU to NAND), or NAND corrupt. |
The reasons, like wrong update, device jailbreak and battery problem, can cause this iOS issue. If you want to fix iPhone stuck in boot loop, you might as well simply force restart, use iTunes, or repair with iOS system recovery or something else, like Volumn Up trick, etc. Hope you can get out of this trouble soon. |
Here are different solutions to fix iPhone stuck in boot loop issue. If these solutions are not workable for you, try iOS System Recovery program. |
