Temperature problem Please am having iPhone 6s that is having temperature problems always hot..I have tried many things but don't know the solution please help https://uploads.tapatalk-cdn.com/201...11d559c161.jpg Please check the image please cannot use the phone https://uploads.tapatalk-cdn.com/201...fc41f2fc5c.jpg Sent from my iPhone using Tapatalk Pro |
Is the phone really hot or the temperature warning is fake ? Have you tried new battery and dock connector? Sent from my iPhone using Tapatalk |
The phone is very hot and I have tried new battery and connector Sent from my iPhone using Tapatalk Pro |
Can you check if there are any shorts on the board ? I don't know exactly where the problem will be since water damage so you have to check all board, especially where the hot spots are. Probably you will find a cap shorting or an IC Sent from my iPhone using Tapatalk |
wifi ic I have same problems in my 2 iPhone 6s devices wifi ic getting very hot and temperature warnings if I turn it off (means wifi off) phone works perfectly if I turn it back in just a15 second got error |
Ok.. Sent from my iPhone using Tapatalk Pro |
I have removed wifi module..still getting hot Sent from my iPhone using Tapatalk Pro |
Same here, 2 iPhone 6s wifi chip getting very hot. Its familiar issue. |
No solution Sent from my iPhone using Tapatalk Pro |
change wifi ic,your problem solve |
Just removed the wifi ic okay dont replaced it back |
