12-31-2016, 13:46 | #1 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2484955 Status: Offline Thanks Meter: 14 | IPhone 6 Randomly Restarting Iphone 6 is randomly reboots i tried u2 2times still same and i tried put dfu mode than i installed ios now its gives error 9 on itunes. Is the problem depending on charging controller ic u1401? I havent this ic but i know its also about charging. And phone when i plug the battery its starting byself . Like pressing power button. Any advice? Thank you |
The Following User Says Thank You to x2xx2x For This Useful Post: |
01-01-2017, 23:03 | #3 (permalink) |
Crazy Poster Join Date: Oct 2016 Location: nederland
Member: 2636928 Status: Offline Thanks Meter: 6 | I would say, try to disconnect the power cable, looks if it still booting when connecting the battery. if i don't put in charger to start the phone and test it without the flex connected. error 9 also seems to be a NAND problem, but I don't have enough experience with that. if the battery is bad (phone don't get information) the phone will reboot after a few minutes. if you find your solution, please post it to help others. |
01-03-2017, 21:52 | #4 (permalink) |
Member: 2484955 Status: Offline Thanks Meter: 14 | Battery is good. Its also doing it when i supply with power supply. I think its about charging and usb connection problem. On the board about usb and charge ic's i will change than i will write solution if i can find a way... Thanks |
