02-06-2017, 18:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | iPhone 6 DFU Error 4005 Tristar has been replaced twice and still it won't boot. I can force it into DFU and iTunes detects it in recovery mode. When I try it hangs at "waiting for iPhone" and eventually gives error 4005 |
02-06-2017, 23:19 | #2 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Russia - Izhevsk
Member: 2681265 Status: Offline Thanks Meter: 97 | Before replacing Tristar device turned on? The DFU forcibly or automatically defined? |
The Following User Says Thank You to PRO-mobile For This Useful Post: |
02-06-2017, 23:21 | #3 (permalink) |
Member: 2598526 Status: Offline Thanks Meter: 52 | Owner says it worked perfectly before Tristar replaced. It wasn't done by me. I did try another Tristar and same result Have to force it into DFU otherwise hangs at 60ma when powered on |
The Following User Says Thank You to short_toground For This Useful Post: |
02-06-2017, 23:38 | #4 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453408 Status: Offline Thanks Meter: 63 | booting to itunes nute? or just going into DFU? DFU and recovery mode are different modes and you wrote it in a little confusing way If iphone goes into DFU mode then its not reading NAND or there is corrupted firmware in NAND, otherwise it goes into recovery mode |
02-06-2017, 23:51 | #6 (permalink) | |
Member: 2598526 Status: Offline Thanks Meter: 52 | iPhone 6 DFU Error 4005 Quote:
Ok so nothing happens unless I hard reset by pressing home button then iTunes recognizes it in recovery mode. There is never a display I just hold power and home buttons for 10 seconds and release continuing to hold home button so iTunes detects it. Is that DFU mode? If I don't do that iTunes never detects the phone | |
02-07-2017, 00:55 | #10 (permalink) | ||
Member: 2453408 Status: Offline Thanks Meter: 63 | Quote:
if there is no display then its probably DFU and if its not going into DFU without your intervention then it probably boot loops on some early boot panic PRO-mobile may be right, power surge from this crap charger could damage memory through PP1V8_SDRAM which is used by both tristar and memory, but its only guess, it could be anything start by measuring important voltages, check that PP1V8_SDRAM and so I think | ||
02-07-2017, 00:59 | #11 (permalink) | |
Member: 2598526 Status: Offline Thanks Meter: 52 | Quote:
Yes checked 1.8v and 1.2v sdram both are there. So aren't CPU, nand, reset voltages | |
02-07-2017, 03:35 | #12 (permalink) |
Member: 2598526 Status: Offline Thanks Meter: 52 | iPhone 6 DFU Error 4005 Also I removed NAND to reball and without the NAND iTunes auto detects it in DFU. With NAND reballed iTunes doesn't detect it unless I force it in DFU like the original issue |
02-07-2017, 13:22 | #15 (permalink) |
Member: 2681265 Status: Offline Thanks Meter: 97 | If the upgrade Progress bar appears, it is not exactly CPU and DDR, if not displayed, then check whether for the Nand core voltage, if you do, then it's the CPU or DDR. |
