Old 02-20-2014, 14:29   #1 (permalink)
krish491's Avatar
Member: 603777
Thanks Meter: 356
Procedure to unlock lava- l661 via cdma-tool
here is method of L661 unlocking from CDMA-TOOL
1.First select L661
2.Select modem port and click diag enable.
3.Click read info to check if diag enable is ok.
4.Select diagnostic port and then click write efs.
5.Just write EFS only from below file
6.Your handset is unlock.
here is link of flash file
no need flash, then input unlock code.
no need to buy any other tool!!
Download nor.rar from Sendspace.com - send big files the easy way
all version will be unlocked via this method no need of downgread and other method
Last edited by Infinity-CDMA; 02-21-2014 at 16:07. Reason: some information added.
The Following 2 Users Say Thank You to krish491 For This Useful Post:
Old 02-21-2014, 01:43   #2 (permalink)
gb2qaz's Avatar
Member: 441202
Thanks Meter: 120
Cool File is ok unlock write full flash then unlock
Originally Posted by krish491 View Post
here is method of l661 unlocking from cdma-tool
1.first select l661
2.select modem port and click diag enable.
3.click read info to check if diag enable is ok.
4.select diagnostic port and then click write efs.
5.just write efs only from below file
6.your handset is unlock.
Here is link of flash file
No need to buy any other tool!!
download nor.rar from sendspace.com - send big files the easy way
your step is wrong because after write efs with diag on set shows invalid sim ?:d
but when i was flash with full write flash option set unlock done and work perfectly without any code your file is unlock ok
thanks to infinity team for l661 flasher work perfect on win 7 also
all above for only unlock test result info for all users
The Following 3 Users Say Thank You to gb2qaz For This Useful Post:
Old 02-21-2014, 03:23   #3 (permalink)
gb2qaz's Avatar
Member: 441202
Thanks Meter: 120
FLASHCHIP : SPANSION S71VS128RB0d=======W.A.R.N.I.N.G=======
DO NOT REMOVE THE PHONE..!!
Flashing : 16777216/16777216
done...
Finished, time used: 7 min 56 sec
Old 02-21-2014, 16:04   #4 (permalink)
Infinity-CDMA's Avatar
Member: 1319166
Thanks Meter: 1,476
Please post us read info log.
Hi,
Thanks for test report Please post us logs of read info to check is it supported or not or protection not is efs may be in firmware so after flash you changed whole firmware and phone got unlocked .
Phone which i have in hand have this info :
HARDWARE : SBNAAHZ3
COMPILE : Jul 25 2013 (10:42:15)
REALEASE : Apr 29 2011 (05:00:00)
SW Version : Q1110 SBNAAHZ 3390 fh
Phonce code : 0000
Finished, time used: 1 sec
and it work perfect just with efs flashing.
Regard's
Infinity-CDMA
Old 02-22-2014, 15:20   #5 (permalink)
Member: 873465
Thanks Meter: 7
Thanks to infinity team for l661 flasher work perfect
Write Full Flash set is Unlock Done
The Following User Says Thank You to Ram M.T.D For This Useful Post:
Old 02-22-2014, 16:35   #6 (permalink)
Member: 1492933
Sonork: 100.1646938
Thanks Meter: 56
please upload file to other server like 4 shered .
The Following User Says Thank You to sajid r shaikh For This Useful Post:
Old 02-23-2014, 08:01   #7 (permalink)
Member: 1069446
Thanks Meter: 48
done...
Finished, time used: 8 min 38 sec
THNXXXXXXXX infinity team and who tested this solution
The Following User Says Thank You to asiftak For This Useful Post:
Old 02-23-2014, 08:06   #8 (permalink)
Member: 1069446
Thanks Meter: 48
thnxxxxxxxxx gb2kaz and krish491
Old 02-24-2014, 12:46   #9 (permalink)
Member: 2131112
Thanks Meter: 3
thanx to inifnity team for good update .............
The Following User Says Thank You to malethia For This Useful Post:
Old 02-26-2014, 21:07   #10 (permalink)
gb2qaz's Avatar
Member: 441202
Thanks Meter: 120
Originally Posted by Infinity-CDMA View Post
Hi,
HARDWARE : SBNAAHZ3
Phonce code : 0000
Regard's
Infinity-CDMA
HARDWARE : SBNAAHZ3
COMPILE : Oct 12 2013 (11:09:48)
Phonce code : 0000
Finished, time used: 3 sec
Old 02-27-2014, 20:56   #11 (permalink)
krish491's Avatar
Member: 603777
Thanks Meter: 356
HARDWARE : SBNAAHZ3
Phonce code : 0000
New Version!!!!
Need to full Flash!!!!
it will be unlock via this method, i can say world first and only in the world
Old 03-01-2014, 16:59   #12 (permalink)
gb2qaz's Avatar
Member: 441202
Thanks Meter: 120
New Version!!!!
unlocking ok but sorry for world first all knows many peoples are doing from a long time ago
Old 03-03-2014, 06:43   #13 (permalink)
Member: 1107485
Thanks Meter: 73
@krish491 THANKS ...for information..only flash ..and set will unlocked......
Old 05-21-2014, 13:35   #14 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 183
COM80 [QCUSB_COM80_1] selected
module v2.04
Device: Lava-L661
operation: Write EFS
Phone should be Switched ON !
connecting...
initializing...
reconnecting...
Wait reconnecting port...
detecting port
port ok..
sending bootloader...
detecting port
port ok..
did not respon...
Finished, time used: 2 min 22 sec
Old 05-21-2014, 14:59   #15 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 183
HARDWARE : SBNAAHZ3
Phonce code : 0000
Finished, time used: 4 sec
Page generated in 0.20896 seconds with 8 queries
