2 boxes dead after update... need help my 2 boxes were asking for updates in order to resurrect i747 well i did and this is whats happening now. tried with t959, t999, i717, i747... and the same error no response from box... before was working great with Firmware Version: 1.32 [12/13/2012 2:50:31 PM] [START OPERATION_ID = RESURRECT] [12/13/2012 2:50:39 PM] Open serial port...OK [12/13/2012 2:50:39 PM] Connecting to the RIFF Box...OK [12/13/2012 2:50:39 PM] Firmware Version: 1.34, JTAG Manager Version: 1.48 [12/13/2012 2:50:39 PM] Selected Resurrector: [Samsung I747 V1.0.4707.53821] [12/13/2012 2:50:39 PM] [12/13/2012 2:50:39 PM] Connecting to the dead body...OK [12/13/2012 2:50:39 PM] Detected dead body ID: 0x406B50E1 - CORRECT! [12/13/2012 2:50:39 PM] Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK [12/13/2012 2:50:39 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [12/13/2012 2:50:39 PM] [12/13/2012 2:50:39 PM] Resurrection sequence started. [12/13/2012 2:50:39 PM] Establish communication with the phone...OK [12/13/2012 2:50:39 PM] Initializing internal hardware configuration...OK [12/13/2012 2:50:39 PM] Uploading resurrector data into memory...OK [12/13/2012 2:50:39 PM] Starting communication with resurrector...FAILED [12/13/2012 2:50:39 PM] ERROR: No response from the RIFF Box. [12/13/2012 2:50:39 PM] [FINISH OPERATION_ID = RESURRECT] |
There is no problem in Box Firmware hardware ETc check the Phone pinouts be sure you connect the wire well |
The box was working fine minutes before i updated it... All wires and the hardware box is fine... The problem was the update. :mad: |
I have same problem,Box work perfektly,after Update no Resurrection,tested on many Phones. I have Downgraded and update the Riff Box Firmware,but not work same Problem. |
Hi New Jtag Manager and New Box Firmware Work Properly Without any problem...i did resurrect more than 50pcs In the past 2 weeks:D So,You need Check "Pinout,usb,power supply" Or,Check with different Speed .. Please check I747 with RTCK 1MHZ Speed |
RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. and im stock with this big problem |
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9001 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x27B360E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. me also having this problem pls check riff team!!!!!!!!! |
