11-04-2013, 16:08 | #1 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 393902 Status: Offline Thanks Meter: 4 | i535 dead after bad flashing by odin After ressurection still dead, no download mode. Code: [2013-11-04 15:04:14] [START OPERATION_ID = RESURRECT] [2013-11-04 15:04:15] Open serial port...OK [2013-11-04 15:04:15] Connecting to the RIFF Box...OK [2013-11-04 15:04:15] Firmware Version: 1.37, JTAG Manager Version: 1.55 [2013-11-04 15:04:15] Selected Resurrector: [Samsung I535 V1.0.4899.12662] [2013-11-04 15:04:15] [2013-11-04 15:04:15] Connecting to the dead body...ERROR [2013-11-04 15:04:15] ERROR: The RTCK Signal does not respond. [2013-11-04 15:04:15] [FINISH OPERATION_ID = RESURRECT] [2013-11-04 15:04:26] [START OPERATION_ID = RESURRECT] [2013-11-04 15:05:06] Open serial port...OK [2013-11-04 15:05:06] Connecting to the RIFF Box...OK [2013-11-04 15:05:06] Firmware Version: 1.37, JTAG Manager Version: 1.55 [2013-11-04 15:05:06] Selected Resurrector: [Samsung I535 V1.0.4899.12662] [2013-11-04 15:05:06] [2013-11-04 15:05:06] Connecting to the dead body...OK [2013-11-04 15:05:06] Detected dead body ID: 0x706B10E1 - CORRECT! [2013-11-04 15:05:06] Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK [2013-11-04 15:05:06] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [2013-11-04 15:05:06] [2013-11-04 15:05:06] Resurrection sequence started. [2013-11-04 15:05:06] Establish communication with the phone...OK [2013-11-04 15:05:06] Initializing internal hardware configuration...OK [2013-11-04 15:05:06] Uploading resurrector data into memory...OK [2013-11-04 15:05:06] Starting communication with resurrector...OK [2013-11-04 15:05:06] [2013-11-04 15:05:06] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MAG4FB, 0x0003AB400000 Bytes = 14.68 GB) [2013-11-04 15:05:06] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MAG4FB, 0x000000200000 Bytes = 2.00 MB) [2013-11-04 15:05:06] [2013-11-04 15:05:06] Selected Resurrection Data for the eMMC Chip with Capacity = 14,68GB [2013-11-04 15:05:06] [2013-11-04 15:05:06] Flashing the dead body...OK [2013-11-04 15:05:06] Resurrection complete! [2013-11-04 15:05:06] [FINISH OPERATION_ID = RESURRECT] [2013-11-04 15:05:18] [START OPERATION_ID = GET_DEVICE_ID] [2013-11-04 15:05:18] Open serial port...OK [2013-11-04 15:05:18] Connecting to the RIFF Box...OK [2013-11-04 15:05:18] Firmware Version: 1.37, JTAG Manager Version: 1.55 [2013-11-04 15:05:18] Selected Resurrector: [Samsung I535 V1.0.4899.12662] [2013-11-04 15:05:18] [2013-11-04 15:05:18] Connecting to the dead body...OK [2013-11-04 15:05:18] Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK [2013-11-04 15:05:18] [2013-11-04 15:05:18] Detected dead body ID: 0x706B10E1 [2013-11-04 15:05:18] [FINISH OPERATION_ID = GET_DEVICE_ID] Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung I535 V1.0.4899.12662] Connecting to the dead body...OK Detected dead body ID: 0x706B10E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x070100000000000000000003AB400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0000 (MAG4FB, 0x0003AB400000 Bytes = 14.68 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0000 (MAG4FB, 0x000000200000 Bytes = 2.00 MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:00.000 (Average Transfer Rate: N/A) Reading FLASH1 address space from 0x000000004400 to 0x0000000045FF Completed in 00:00:00.016 (Average Transfer Rate: 131071999.94 kB/s) Reading FLASH1 address space from 0x000000000000 to 0x0000000001FF Completed in 00:00:00.016 (Average Transfer Rate: 1312.50 kB/s) Reading FLASH1 address space from 0x000000004400 to 0x0000000053FF Completed in 00:00:00.032 (Average Transfer Rate: 656.25 kB/s) Analizing the FullImage File...OK Current Phone/Image File has PIT Structure. PIT Descriptor: COM_TAR2MSM8960 Total quantity of listed partitions: 27 Code: Checking which Partition is blank...COMPLETE! Following partitions are found to be completely blank: Partition: MD5 at 0x000000006400 Partition: MODEM at 0x000000400000 Partition: SBL1 at 0x000004000000 Partition: SBL2 at 0x000004020000 Partition: SBL3 at 0x000004060000 Partition: ABOOT at 0x0000040E0000 Partition: RPM at 0x0000042E0000 Partition: BOOT at 0x000004360000 Partition: TZ at 0x000004D60000 Partition: PAD at 0x000004DE0000 Partition: PARAM at 0x000004E60000 Partition: EFS at 0x000005860000 Partition: MODEMST1 at 0x000006600000 Partition: MODEMST2 at 0x000006900000 Partition: SYSTEM at 0x000006C00000 Partition: USERDATA at 0x000064800000 Partition: PERSIST at 0x000373C00000 Partition: CACHE at 0x000374400000 Partition: RECOVERY at 0x0003A8C00000 Partition: FOTA at 0x0003A9600000 Partition: BACKUP at 0x0003AA000000 Partition: FSG at 0x0003AA600000 Partition: SSD at 0x0003AA900000 Partition: GROW at 0x0003AA902000 Partition: SGPT at 0x0003AB3FBE00 Thus in total, there are 25 blank partitions. br Tommi |
11-04-2013, 18:55 | #4 (permalink) | |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
If phone HW is okay, yes You can. If phone HW is NOT OK, again You can, if You repair HW. But since I don't know You personally and have no idea about Your skills, this is in "might be" domain. | |
11-04-2013, 20:30 | #5 (permalink) |
Member: 393902 Status: Offline Thanks Meter: 4 | Ha ha We laughed but now it's time to work. Phone worked fine and was bricked when the customer flashed it. I wanted to ask HOW to do it because I resurrected it by riff and the phone is still dead. How to repair and put it into download mode because now screen is only black. I know You CAN help me |
