10-23-2012, 10:25 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Indonesia
Member: 1199611 Status: Offline Thanks Meter: 23 | x10 dcc write help I use dump file from here result, the phone is only vibrate when powered on. i already write TA and repair imei. expert, please help... BR |
10-23-2012, 10:41 | #2 (permalink) |
Member: 1199611 Status: Offline Thanks Meter: 23 | Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.43 Selected Resurrector: [SE X10i V1.00] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.60V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x21020000000000000000000040000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x002C/0x55B3 (1024MB) Writting FLASH2 memory from 0x000000000000 to 0x00003FFFFFFF Completed in 00:55:48.094 (Average Transfer Rate: 322.97 kB/s) |
