Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Junior Member ![]() Join Date: Oct 2010
Member: 1430325 Status: Offline Thanks Meter: 4 | death machine T-01A(TG01) I use the EPS file to unlock,can not boot after。 ![]() And later with the resurrection Operations are as follows: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) Unlocking the Phone...OK Unlock complete! Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [Toshiba TG01] Connecting to the dead body...OK Detected dead body ID: 0x202400E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB) Flashing the dead body...OK Resurrection complete! Now dead, can not boot normally Connect pin A to pin B on phone and hold the power button, my T-01A dont start, no screen, no enter download mode ,no nothing. Connect pin A to pin B on phone and hold the Reset button is the same. |
![]() | #2 (permalink) |
Junior Member ![]() ![]() Join Date: Aug 2006
Member: 322618 Status: Offline Thanks Meter: 5 | To flash TG01 You need the following : - TG Downloader - TG USB Drivers - TG Tool and TSW file or already decrypted bin file http://rapidshare.com/files/421984854/tg01.rar Install TG Downloader and TG USB Drivers first, and reboot the PC. Connect pin A to pin B on phone and hold the power button. Phone will enter download mode, Windows will find new device, and install drivers. Start the TG Downloader with admin rights, and open the *.bin file. TG Downloader will report error with version, You need to press YES. Now You need to select Toshiba DL port in port settings and after confimation, press “Download mode”. Phone will be booted, and You can press “Download” now. Now simply wait for download process to be finished. Credits for this solution go to xda-developers portal! |
The Following User Says Thank You to why_no For This Useful Post: |
![]() | #3 (permalink) | |
Member: 1430325 Status: Offline Thanks Meter: 4 | Quote:
windows and no new device, that no response | |
![]() | #4 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: heart of Asia Age: 43
Member: 311316 Status: Offline Thanks Meter: 41 | TOSHIBA TG01 not powering on hi supporter after unlocked tg01 powering well but lock code changed i trying hard reset but phone not ON flashed, again unlocked just show splash screen again unlocked and flashed just blink green led how to flash Toshiba_TG01_Unlocked_Full_backup.bin this file? and which model select at factory downloader? help me? |
![]() | #6 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Age: 54
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,275 | http://forum.gsmhosting.com/vbb/f634...nuals-1051474/ Check full backup link, and also instructions how to restore full backup. |
![]() | #7 (permalink) |
Member: 1430325 Status: Offline Thanks Meter: 4 | I have a full backup before unlocking the 528M BIN file, I restore the backup, but my phone still can not boot, can not flash, no response Last edited by legija; 11-03-2010 at 10:38. |
![]() | #9 (permalink) | |
- Switch to "DCC Read/Write" TAB - Select "Access ROM1 Address Space" - Check "Auto Fullflash size" - In "main" field open desired backup file - Check "Image Files use Used" - Check "Flash files - are full Images" - Click "Write Flash" I'm sure the operation is correct | |
![]() | #10 (permalink) | |
![]() | #11 (permalink) |
Member: 1430325 Status: Offline Thanks Meter: 4 | I heard T-01A board to pull a line to be used when the TG01. But I do not know how to get there RIFF whether to support the T-01A. If I write the official BIN file is feasible, but the BIN file was 248M Headache |
![]() | #15 (permalink) | |
Junior Member ![]() ![]() Join Date: Feb 2006
Member: 228559 Status: Offline Thanks Meter: 3 | Quote:
ERROR: Image file size wrong. Main and Spare not correlate in size. ver 1.19 P.S. dear mr. legia, I need full backup from Japanese T-01A too, pls give me... | |
The Following User Says Thank You to MudriC For This Useful Post: |
Does Nk_calc working on AMD machine? | goetze | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 03-01-2002 00:13 |
No more death Nokia phones!!!!!!!! | Cyberdog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2002 23:24 |
Death 3210 (v???) | iboboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-25-2002 20:56 |
Motorola T2288 DEath :(( Please help | pali | Motorola Old Legacy (EMMI) | 3 | 01-07-2002 22:51 |
3310 v4.02 death | nomestrano | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-30-2001 09:02 |
