ERROR: Stopped due to multiple communication errors. Help!! Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading loader data into memory...OK Starting communication with loader...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0036 (64MB) Writting FLASH1 memory from 0x00000000 to 0x03FFFFFF ERROR: Stopped due to multiple communication errors. Terminating at 0x00000000 |
Hi, Please explain what You want to do, and post COMPLETE log from operation. |
I want to read and write fullflash with RIFFBOX,Read correctly,but fullflash size not 0x03ffffff, is 0x041fffff;write fullflash ERROR! read Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.18 Selected Custom Target: [ARM926, 2.60V, TAP0] Connecting to the ARM926 target...OK Detected Target ID on TAP0: 0x200C00E1 Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading loader data into memory...OK Starting communication with loader...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0036 (64MB) Reading FLASH1 address space from 0x00000000 to 0x03FFFFFF Completed in 00:02:09.422 (Average Transfer Rate: 522.20 kB/s) write Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.18 Selected Custom Target: [ARM926, 2.60V, TAP0] Connecting to the ARM926 target...OK Detected Target ID on TAP0: 0x200C00E1 Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Uploading loader data into memory...OK Starting communication with loader...OK Detected an Initialized FLASH1 Chip ID: 0x00EC/0x0036 (64MB) Writting FLASH1 memory from 0x00000000 to 0x03FFFFFF ERROR: Stopped due to multiple communication errors. Terminating at 0x00000000 |
Hi, What device You have connected please ? |
Engineering mobile pda pxa270 modem msm6280 |
Hi, You can try setting TCK sampling speed to lower value, e.g 1MHz for example. Also, its is possible that PXA cpu controls MSM power, so it can shut down it. |
