g532m 16gb [Solved] please add dll ISP g532m 16gb |
Hi, Can You please read 16 mb from user area partition and upload ? Need this to make DLL. |
1 Attachment(s) If mbr/gpt in phone is intact, You can simply write bootloader file: 1.Download repair firmware or bootlaoder (BL_G532MUMU1AQA3_CL10438829_QB12299624_REV00_user _low_ship_MULTI_CERT.tar) https://androidfilehost.com/?w=file-...12cdfd1c5ce126 2. Start eMMC plugin, click "Parse Connected eMMC" 3. Click "Parse official firmware" and select "BL_G532MUMU1AQA3_CL10438829_QB12299624_REV00_user _low_ship_MULTI_CERT.tar.md5" 4. Click "Flash Selected". If Pit is deleted from phone You can load it from file "GRANDPPLTE_CIS_SER.pit" and on step 2 simply click "parse local file". |
how do I make the backup for you to do the dll |
1 Attachment(s) Set everything as on screenshot, click "read emmc/sd" and when it finish click "Save to file". |
G532m 16gb 1 Attachment(s) Quote:
You forgot to set data length. Please check carefully screenshot and repeat the process. |
where is my mistake I did it as is the image except the model |
You just saved emmc info file, not the user area partition content. Click first button from left (Read eMMC/SD) and when operation is finished click save (as *.bin file). Copy log from software and post here. |
1 Attachment(s) here is compressed, after decompression file is 16mb |
It looks like eMMC is read only. What happens when You click "Resurrection" ? GPT in this model is universal for any chip size, and JTAG Manager should just display message "using data for xxx size chip", but resurrection must finish. |
I managed to make a successful resurrection, I just wrote the backup of user area 16mb and then with eMMC plugin I wrote the boot and it came back to life, I do not understand but I achieved it in 2 G532m of 16 GB chip this is the reading with the resurrector who is already doing the process but it does not work [27/06/2018 11:53:21] [START OPERATION_ID = RESURRECT] [27/06/2018 12:05:16] Open serial port...OK [27/06/2018 12:05:16] Connecting to the RIFF Box...OK [27/06/2018 12:05:16] Firmware Version: 1.50 (RIFFBOX1), JTAG Manager Version: 1.80 [27/06/2018 12:05:16] Selected Resurrector: [Samsung G532F ISP V1.0.6599.17149] [27/06/2018 12:05:16] [27/06/2018 12:05:16] Connecting to the SD/eMMC Card...OK [27/06/2018 12:05:16] Set I/O Voltage reads as 1.80V, SD_CLK Frequency is 649 KHz [27/06/2018 12:05:16] [27/06/2018 12:05:16] Detected eMMC Chip, ID: 0x15/0x00 (Q316BB), User Area Partition = 0x0003AB400000 Bytes (14.68 GB) [27/06/2018 12:05:16] [27/06/2018 12:05:16] No Resurrection Data is available for the eMMC Chip with Capacity = 14,68 GB [27/06/2018 12:05:16] WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 7,28 GB [27/06/2018 12:05:16] [27/06/2018 12:05:16] Flashing the dead body...OK [27/06/2018 12:05:16] Resurrection complete! [27/06/2018 12:05:16] [FINISH OPERATION_ID = RESURRECT] |
Ok. Can You read 512MB from working phone now (user area) ? |
if during the day I'll be making a copy |
