Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 05-31-2013, 15:00   #1 (permalink)
nifboy's Avatar
Member: 645987
Sonork: 100.1612601
Thanks Meter: 112
GT-I9082 ERROR: Wrong response
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.35, JTAG Manager Version: 1.49
Selected Resurrector: [Samsung I9082 V1.0.4896.5945]
Connecting to the dead body...OK
Detected dead body ID: 0x4BA00477 - CORRECT!
Set I/O Voltage reads as 1.80V, TCK Frequency is 9 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...FAILED
ERROR: Wrong response code from the RIFF Box: 0x82
Old 05-31-2013, 15:07   #2 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: 100.1650339[OFFLINE]
Thanks Meter: 1,009
RIFF JTAG Box FAQ - Error code 0x82
BR,
TEJARAM
Old 05-31-2013, 15:33   #3 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,271
Hi,
I'm waiting for You on Sonork.
Old 09-25-2013, 21:24   #4 (permalink)
Bruno Rafael's Avatar
Member: 700706
Sonork: 100.1590381
Thanks Meter: 207
some problem;.....
how to solve?
jtag manager 1.51
box firmware 1.37
model select: i9082
my phone model : i9082L
error 0x82
Old 09-25-2013, 21:36   #5 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 207
Firmware Version: 1.37, JTAG Manager Version: 1.51
Selected Resurrector: [Samsung I9082 V1.0.4905.50548]
Set I/O Voltage reads as 1.79V, TCK Frequency is 8 MHz
Settings Code: 0x05010B00000000000000000020000000
Old 09-26-2013, 01:46   #6 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 207
how to make this cable?
http://forum.gsmhosting.com/vbb/9458274-post9.html
Legija says it exists but do not teach ....
Old 09-26-2013, 11:21   #7 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 207
Product supporters Where are you please help me its urgent
Old 09-26-2013, 22:51   #8 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,465
Hi
0x82 error have a few reason
1-bad soldered jtag wires
2-power not good....,Use power supply
3-use usb cable or usb+jig
but,
in new BCM if Rom2 erased,we can't access via jtag interface
Thanks
Old 09-27-2013, 11:00   #9 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 207
wires soldered station Ok
how to know if it's new bcm ROM2?
+ usb jig? did not understand ....
I pay the cable Riff and put in a usb cable original 10cm + or -
Old 09-28-2013, 12:26   #10 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 207
Babak Nuri
No reply for me ?
Old 10-07-2013, 14:35   #11 (permalink)
Member: 219803
Sonork: 1582317
Thanks Meter: 37
Mr.legija I have same problem right now. Could you please contact me on my sonrok if you have any idea?
Old 01-27-2014, 17:28   #12 (permalink)
Member: 459220
Sonork: 100.1590597
Thanks Meter: 85
the same problem and not solved
Firmware Version: 1.37, JTAG Manager Version: 1.55
Set I/O Voltage reads as 1.80V, TCK Frequency is 8 MHz
The Following User Says Thank You to GAMMAHIGH For This Useful Post:
Old 02-19-2014, 00:12   #13 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
same problem here,
Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz]
the only solution after rewriting rom2 we can connect phone via JTAG connection and repair boot
Old 02-19-2014, 08:07   #14 (permalink)
Member: 1681461
Thanks Meter: 1,009
Originally Posted by LordMen007 View Post
same problem here,
read this
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.26947 seconds with 7 queries
