Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 02-16-2014, 14:52   #1 (permalink)
Winston rio hum's Avatar
Member: 631496
Sonork: 100.1581341
Thanks Meter: 112
P3100 Restart
need help p3100 hang and restart after few second in menu
i try factory reset complete but still same.
i try flash dith odin falied
when go to recovery menu show
applied multi-csc
applied the CSC-code :xse
did not match sized '/system/csc/common/system/csc/feature.xml' ( No Data Available)
whats the problem sir
Old 02-16-2014, 19:15   #2 (permalink)
skyulock's Avatar
Member: 757064
Sonork: 11111111
Thanks Meter: 365
applied multi-csc
repair boot with riff box bein flasher the fone again ...................
Old 02-17-2014, 04:16   #3 (permalink)
Member: 631496
Sonork: 100.1581341
Thanks Meter: 112
ressurection u mean ?
Old 02-17-2014, 07:42   #4 (permalink)
Member: 631496
Sonork: 100.1581341
Thanks Meter: 112
Connecting to the dead body...OK
Detected dead body ID: 0x3BA00477 - CORRECT!
Set I/O Voltage reads as 2.61V, TCK Frequency is 8 MHz
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
WARNING: DCC Loader was unable to initialize FLASH1 chip. Error code: 0x00000043
No Resurrection Data is available for the eMMC Chip with Capacity = 0B
WARNING!!! Using Resurrection Data for the eMMC Chip with Capacity = 7.28GB
ERROR: Selected FLASH Chip was not initialized by the DCC Loader
whats the problem i use dll file p3100 xloader
Old 02-17-2014, 09:36   #5 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
i see in your log,eMMC is damaged....But if you have alive phone,Check Soldered Wires...
Old 02-22-2014, 11:05   #6 (permalink)
Member: 631496
Sonork: 100.1581341
Thanks Meter: 112
I try ressurector complete .. but still same. Nothing change still did not find csc???
Old 02-22-2014, 14:10   #7 (permalink)
Member: 631496
Sonork: 100.1581341
Thanks Meter: 112
Originally Posted by BABAK NURI View Post
Hi
i already ressurection and success no problem but nothing happen phone still
applied multi-csc
if my emmc damage. i replace with a new one. tell me the procedure to write with riffbox. need solution urgent
Old 02-24-2014, 06:32   #8 (permalink)
Member: 631496
Sonork: 100.1581341
Thanks Meter: 112
how procedure in riffbox anyone can explain step if i change new emmc for p3100
Old 02-24-2014, 08:00   #9 (permalink)
Member: 1802331
Thanks Meter: 13
Hi,
Change eMMC then go to downloading and flash your device... if after you changed emmc and didn't have downloading then you need to resurrect your phone then do the rest... nothing special..
Good Luck
Old 11-20-2014, 06:28   #10 (permalink)
MobileCarein's Avatar
Member: 2217517
Sonork: 1660095
Thanks Meter: 24
p3100
applied multi-csc
applied the CSC-code :inu
Old 11-20-2014, 08:41   #11 (permalink)
Member: 2217517
Sonork: 1660095
Thanks Meter: 24
experts the tab p3100 is in working condition but the apps cannot be removed or the data cannot be deleted the tab gets restarted every 5 min while reset i get this menu at the bottom
applied multi-csc
any one have solved this fault if yes pls share the solution
Old 01-21-2015, 15:34   #12 (permalink)
Crazy Poster
Member: 1174676
Thanks Meter: 2
please solusi legija team
Old 04-22-2015, 03:25   #13 (permalink)
Member: 2220289
Thanks Meter: 3
applied multi-csc
how to wipe data solutions but do not get lost? without changing EMMC?
please helpmy sir
Old 05-08-2015, 05:34   #14 (permalink)
Member: 106488
Thanks Meter: 24
same problem with p5110 restart and error in csc did not match sized '/system/csc/common/system/csc/others.xml'
Old 05-17-2015, 03:44   #15 (permalink)
Registered User
Member: 1784151
Sonork: 0
Thanks Meter: 75
i got S6310 today with the same error
did not match sized '/system/csc/common/system/csc/others.xml' (no data available)
Page generated in 0.19678 seconds with 8 queries
