How Fix BadBlocks on HD2's Nand, if possible! Hi Folks, I've been handle some HTC HD2 Logic boards that suddenly stop to work and they pass trough Ressurection process but there are some badblocks on NAND which does not allow to install stock RUU or even write flash directly on the NAND. Is there any way to fix it, fix the bad blocks or moving the required data to other fields like we can do on Windows PC? On the Riff box, choose the Ignore option does not help much, it does the process but seens to not fix the issue, maybe that's why on the "Ignore" button are a small bomb! Check the picture bellow http://www.scorcci.com.br/images/hd2e.jpg Anyway, what we can do about it? Is there any chance to fix this problem on the logic board or they are really dead forever! Thank you very much again for your attention. |
Bad blocks arent the problem there, rather its faulty QSD8250 which gets overheated and fails on radio flashing. You can replace CPU, and NAND will work even with 5% of bad blocks. |
