htc incredible s710e need help urgent Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.45 Selected Resurrector: [HTC Incredible S V1.00] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0070/0x0000 (MMC04G, 0x000086C00000 Bytes = 2.11 GB) Flashing the dead body...OK Resurrection complete! after resurrection it is not detected download mode problem was dead while update |
There is no download mode in HTC. Install drivers by installing HTC Sync. Press vol down + power. You will enter HBoot. press power to enter fastboot mode. Flash ruu when PC has drivers ready |
Please run this command and post result here: "fastboot getvar all" ------------------------ Also you can set cid to 11111111 and flash phone with latest 3.xx.xxx.xx RUU |
ONE DOUBT IF I DID CHANGE (11111111) THEN I WONT BE CREATE GOLD CARD & S-OFF PROCESS PLS EXPLAIN WHY WE DO PUT (111111111) FOR THAT FLASH? IF WE GIVE (222222222) WONT BE WORK PLS EXPLAIN |
if i was change cid 11111111 is SuperCID, this allows you to install any signed RUU without regional restrictions . is it correct |
