06-01-2012, 07:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | [Solved] One V (PK7611000) Bell Canada can't connect just saw ur new update, so i gave it a try on Bell Version One V from other tool, it reads out SPL=1.16, but Model ID is PK7611000, also Primou_2 I connect TP, connect USB then connect battery, computer finds it as QDLoader blah blah, and when i run the program, RiffBox turns device to DCC Loader port, and the porgram just hangs at "Starting Communication with resurrector ..." any idea?? phone is working 100% fine, just wanna try the unlock ~ |
06-01-2012, 09:19 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | How about posting log from operation ? BTW, Correct sequence for TP procedure is this: - TP to GND - Connect Battery and USB Cable - Disconnect TP - Execute desired operation If You haven't disconnected the TP, it wont work. |
06-01-2012, 11:14 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: turkey
Member: 384775 Status: Offline Sonork: 100.1605469 Thanks Meter: 159 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4535.13856] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000004000A00 Bytes = 64,00 MB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000140000 Bytes = 1,25 MB) Flashing the dead body...OK Resurrection complete! not any problem for me |
The Following User Says Thank You to cemalefendi For This Useful Post: |
06-01-2012, 11:31 | #4 (permalink) |
Member: 384775 Status: Offline Sonork: 100.1605469 Thanks Meter: 159 | another phone Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4535.13856] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000092400000 Bytes = 2.29 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body...OK Resurrection complete! |
06-01-2012, 14:49 | #5 (permalink) |
Member: 49581 Status: Offline Thanks Meter: 73 | sorry, driver was installed correctly, all procedure was perform correctly ... only problem ... I DIDN'T RESTART COMPUTER ... after restart computer, it went through correctly .. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4535.13856] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000092400000 Bytes = 2.29 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000100000 Bytes = 1.00 MB) Unlocking the Phone...OK Unlock complete! |
The Following User Says Thank You to gwaai For This Useful Post: |
06-01-2012, 18:12 | #6 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | htc one v problem I have htc one v primo dead,i it is detected in few seconds,need to use test point to shortcut GND,anybody have dis assembly manual or service manual for one v? Thanks |
06-05-2012, 08:51 | #7 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Austria Age: 45
Member: 57712 Status: Offline Sonork: 1010 Thanks Meter: 49 | htc one V error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4535.13856] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000092400000 Bytes = 2.29 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM04G, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Terminating at 0x00000008D200 |
06-06-2012, 17:26 | #10 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 998040 Status: Offline Sonork: 100.151982 Thanks Meter: 33 | HTC One V Need help please update htc one v jtag connection pin out Starting communication with resurrector it stop on this massage with timeout please give solution |
06-13-2012, 11:28 | #12 (permalink) |
Freak Poster Join Date: Dec 2010 Location: leb Age: 43
Member: 1474687 Status: Offline Thanks Meter: 91 | htc one v resurrector proplem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector... |
06-13-2012, 11:39 | #13 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, HTC via USB works in two steps - first step is detect phone in QHUSB mode, and upload loader. In second step, loader restarts phone to DCCUSBloader mode and phone should enumerate as new device. Now You have new device detected at usb port, and You should install drivers. It's possible that phone enumerates as "Unknown Device" at this step, and that is hardware problem. If VID&PID are all 00000 - You most probably need to replace eMMC chip. |
06-21-2012, 16:56 | #14 (permalink) |
Member: 1474687 Status: Offline Thanks Meter: 91 | another htc one v resurrector proplem Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.32, JTAG Manager Version: 1.43 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector... |
06-21-2012, 17:31 | #15 (permalink) | |
No Life Poster Join Date: May 2007 Location: QC FAIRVIEW
Member: 504865 Status: Offline Thanks Meter: 213 | i got same error RIFF don't have Concrete solution on HTC right now i don't see any success report regarding resurrection via usb i cant understand these much better if Legia make some Tutorial on these operation Quote:
More that one tone ??? | Nitas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-09-2000 08:55 |
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
