02-24-2014, 12:17 | #1 (permalink) |
Insane Poster Join Date: Feb 2012 Location: Portugal, Funchal
Member: 1720469 Status: Offline Thanks Meter: 12 | Note 10.1 GT-N8010 new board with JTAG disabled? Errors 0x59 and 0x44... I have here a Samsung Galaxy Note 10.1 GT-N8010 that client said he was flashing with battery at 23% and tablet went dead. After opening the tablet I realise that the JTAG interface location is not at the same place as pictured in resurector DLL. Since it was the only 12 pin connector in that area, I asume the one I'm using is the correct JTAG interface (I'm using a 12 pin male connector so to avoid soldering directly to the board). When inserting usb cable and pressing "resurect" phone is not detected... if I press power button briefly, phone is detected and after a while it gives 0x59 error... If I keep pressing the power button, if takes a little longer and gives error 0x44 I'm wondering if this is a new board with JTAG disabled or I'm doing something wrong here? Any help is appreciated... I'm adding photos of the errors and the board. Regards |
02-24-2014, 13:35 | #2 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Yes, that could be. They fused all exynos cpu-s after few weeks of production. There should be sd card method working, though. |
The Following User Says Thank You to legija For This Useful Post: |
02-24-2014, 19:51 | #3 (permalink) |
Member: 1720469 Status: Offline Thanks Meter: 12 | Do you know any link about the SD Card method for this model? I have this item (http://forum.gsmhosting.com/vbb/f549...boots-1692243/) but does not refers the N8010 model... |
04-04-2015, 11:20 | #8 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2373630 Status: Offline Thanks Meter: 0 | I know this is an older thread, but my N8010 is bricked. Some say softbrick is a term Noobs use, but in my case it's rather to the point. I'm able to enter CMW and DL mode, but ODIN 100% fails on whatever rom or pit file. CWM works but fails to mount volumes, so most actions/functions also fail. Now I'm looking into the JTAg method to unbrick/reformat the tablet. My N8010 has two connectors on the place the thread starter said he was missing one of the two. Can someone tell me if my N8010 is a receverable N8010 andif so, post a link to more info on how to get it done? I've added some images of my Jtag connectors and model. Thanks for any help you might be able to give. Unfortunatly I cannot post or upload the two images I wanted to show yoy of my N810 board connectors |
04-05-2015, 09:58 | #9 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Please check ,do you have "Product Name=GT-N8010" in Downloading? or It's blank? if it's blank you have damaged eMMC for 100% if not blank but you can't write anything via Odin,you have corrupted eMMC FW | |
