Huawei B8 Lite L21 ERR[006E], POS[0003] Hi, I am trying to connect via ISP with P8 Lite and got following errors Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.51 (RIFFBOX2), JTAG Manager Version: 1.81 Selected Resurrector: [Huawei P8 Lite (ALE-L21) ISP V1.0.6732.51839, <eMMC/SD & GPIO>, 1 Bit Bus Width (DAT0)] Connecting to the SD/eMMC Card...ERROR Set I/O Voltage reads as 2.59V, SD_CLK Frequency is 34 MHz Connecting to the SD/eMMC Card Failed (ERR[006E], POS[0003]) I have double checked wiring and looks correct. Changing I/O voltage and frequency does not help. Any suggestions? |
I'm having the same error, I do not know if it's the box or what?. |
That's too bad. Phone is locked with security code and I was hoping this way I will recover the data. Is this a Riff bug? |
Did anyone suceed to read EMMC from P8 Lite using Riff? |
I have checked today BUS with oscilloscope. CLK and COMMAND looks corect however there is nothing on DATA0, only some noise when clock is active. I have tried with different Pull UP or Down resistors but no effect. Is this DATA0 pinout confirmed? |
Posted by black-micron so 100% tested. Possibly dat0 not scratched on correct place or badly soldered. |
Wiring double checked and re-soldered. Trials with external power supply also without success. Case closed as not-solved. |
