Huawei U8815 Huawei U8815 - G300 problem with resurrection :( any help would be greatly appreciated Quote:
phone can connect via usb as HS-USB Diagnostics port |
Hi Please Read:RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. |
yes, itried, the same result :( |
Code: Open serial port...OK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Set I/O Voltage reads as 2.61V, TCK Frequency is 1 MHz Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz] ERROR: No response from the RIFF Box. |
another phone same problem Code: Open serial port...OK |
? Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Huawei U8815 V1.0.5256.55735] Connecting to the dead body...OK Detected dead body ID: 0x106230E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
