i8000 dead boot, error in riffbox pls help me... what is wrong with my procees in repairing, first time using this fresh box... pls help.. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.21 Selected Resurrector: [Samsung I8000] Connecting to the dead body...OK Detected dead body ID: 0x07B76F0F - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
Target detected, but operation cannot be finished : Code: Connecting to the dead body...OK Detected dead body ID: 0xA01700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. : Code: Connecting to the dead body...OK Detected dead body ID: 0x301700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: DCC Loader Execute failed. Terminating. ... Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [HTC Rhodium W] Connecting to the dead body...OK Detected dead body ID: 0x301000E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: Memory access timed out. 1. Check if NRST signal is connected 2. Change RTCK Sampling from "Sample At Max" to lower value, for example 1MHz 3. Check target power and connection i8000 has no nrst connection base on the interface pin-out and resurrection help.... how can we resurrect this unit sir? |
pls.... need responce in this problem... there's somebobody said it may be box problem... |
How about RTCK Sampling? Did you tried to set lower value ? |
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.29 Selected Resurrector: [Samsung I8000] Connecting to the dead body...OK Detected dead body ID: 0x07B76F0F - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
Please help me I have same problem |
