05-28-2013, 09:22 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Canada Toronto
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | samsung m200s options show |
05-28-2013, 11:16 | #2 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Usually You need check both So, first select 0x4020,,,Then check phone for "downloading" if not start,Try with 0x33 |
05-28-2013, 12:14 | #3 (permalink) |
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung M200S V1.0.4787.59328] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Detected an Initialized FLASH2 Chip, ID: 0x0002/0x0100 (SEM16G, 0x0003B5400000 Bytes = 14.83 GB) Detected an Initialized FLASH3 Chip, ID: 0x0002/0x0100 (SEM16G, 0x000000100000 Bytes = 1.00 MB) Flashing the dead body...OK Resurrection complete! set not on ....where is problem!! |
05-28-2013, 16:42 | #7 (permalink) |
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung M200S V1.0.4787.59328] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Settings Code: 0x00020B00000000000000000000100000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Detected an Initialized FLASH2 Chip, ID: 0x0002/0x0100 (SEM16G, 0x0003B5400000 Bytes = 14.83 GB) Detected an Initialized FLASH3 Chip, ID: 0x0002/0x0100 (SEM16G, 0x000000100000 Bytes = 1.00 MB) Reading FLASH2 address space from 0x000000000000 to 0x0000000FFFFF ERROR: Read Failed with Error Code: 0x28. Terminating at 0x000000000000 Read Memory with 1MB yte Data Lenght !!! any one tell me where is eMMc ? |
09-13-2014, 07:40 | #12 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | odin not supported in this model, flash via cmd If you have downloaded the kernel, radio or rekaveri format * .img, sew them to be similar to the firmware via fastboot ClockworkMod Recovery (manual above) Download the kernel image / radio / rekaveri, put it in the folder C: \ android \ adb and rename them boot.img / radio.img / recovery.img respectively (for convenience) Turn off the phone and turn it into a bootloader (stifle button Volume Up + Power), connect the USB-cable. On the PC, go to the command prompt (Start - Search programs and files - cmd - Enter or Start - All Programs - Accessories - Command Prompt) To go to the desired folder on the command line write: cd C: \ android \ adb To flash the kernel using the following command: fastboot flash boot boot.img For flashing radio: fastboot flash radio radio.img For firmware rekaveri: fastboot flash recovery recovery.img |
